Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 09-07-2007   #1 (permalink)
First Triumph (1964 T120) Need Advice
Hello, I just purchased my first Triumph, and am very excited to learn about, and fix her up.
It is a 1964 T120 frame with a 1969 T120V engine, that has been chopped into a hard tail bobber.
The engine starts right up and runs great. The frame was cracked, so I took everything off and found 2 other breaks and am currently having that worked on.
My questions are:
While I have the engine off I plan on replacing all the cables and hoses. But I would like to do as much as possibly while its off to clean/fix it up... is there anything you would suggest doing?
What is the best oil (and gear oil) to use when I change that? Synthetic?
Would it be okay to put degreaser on the engine and pressure wash her?
Anything you would recommend is very appreciated, I am eager to make this a great bike.
Thanks
Distracto is offline   Reply With Quote
Old 09-07-2007   #2 (permalink)
Favorite Bike: 2007 Scrambler
rmak's Avatar
Greetings!
Welcome, Distracto. About the best advice I can give you on that '64 is to sell it to me quick. It's junk and you won't like it.....no, just kidding.
You probably would be better off asking those guys in the Classic, Vintage and Veteran forum these technical questions. I've been reading the posts over there about vintage bikes and they know their stuff.
It's included in the Classics and Cruisers Discussion Forums in the column on your left.
rmak is offline   Reply With Quote
Old 09-07-2007   #3 (permalink)
$10 bucks cash its your's.... jk
Thanks for the tip, I didn't even see that one. I'll try there.
Old 09-07-2007   #4 (permalink)
Hello Distracto. What I would do, since the motor runs, is before I took it out of the frame is check everything I could while it's in there, like the compression for example. If you can, check the electrical parts for voltage output, charging system, oil leaks, etc, then take the motor out. Many things are easier accomplished while on a bench, like pistons/rings, valves etc. If all is good with it, then just clean it up. Certainly get a Haynes manual for that model; you'll need it.
Good luck!
davidc is offline   Reply With Quote
Old 09-07-2007   #5 (permalink)
Other Motorcycle: 66 Bonnie Chop
Set the timing, adjust the carbs. Hope the sludge trap isn't gummed up...
Pop a picture up, I'd love to see it. I'm rebuilding a '66 hardtail Bonnie.
Al
ssjones is offline   Reply With Quote
Old 09-08-2007   #6 (permalink)
Favorite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
I will cause great consternation with this !!!
[SPLIT THE CASES AND CLEAN AND INSPECT THE SUMP!!!!!!!!
Now is the time I do not care how well it seems to run now there is absoultly no way to tell if it is CLEAR, or 75% plugged!!
If you Do not want to tackle this yourself check out collinscycle.com they are the only, only Triumph shop I've been to in years. They do restorations for customers all over the world and will be fair on the money and it will be right!
If you look recently a lad on the forum screwed up his '67 T120 on the general forum(not sure if this was the problem or not but a good bet).
When they are this old and you do not know the history split the cases now is the time!
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 09-08-2007   #7 (permalink)
Do you feel strongly about this issue, Uziditz?
You are right. Who knows what life this motor lived before.
Old 09-08-2007   #8 (permalink)
uzidzit's Avatar
Yeh!
I have blown a perfect 700 original mile T110 100% clogged!
And I did not learn the lesson and spun a bearing in my old Commando!
sometimes I'm a Little THICK!l
Old 09-08-2007   #9 (permalink)
Steve, the owner of Collins Cycles is a great guy and it's a great shop. They sell new Triumphs and offer vintage parts/service. I stop by every chance I can, which is maybe yearly in my work travels. Steve stops what he is doing to talk to me and show me updates, etc. I'd buy a new (or used) bike from him in a heartbeat. They are just East of Pittsburgh.
http://www.collinscycle.com/
Al
Old 09-08-2007   #10 (permalink)
Is that the Sludge Trap I have been reading about?
http://www.thehorsebc.com/sludge%20trap.htm
I think I am going to try tackling these sorts of things on my own, as I would like to learn about these motors. Just need to get a good manual.
...I actually just found out off the serial number it is a 1972 T120V.
I will try to get some pics up.
My only classic Triumph, 1964... OKcarburetor Twins Talk 6 02-05-2008 11:54 AM
Triumph 1969 T120 - Cut Out Problem Fixed aceaceca Classic, Vintage & Veteran 0 09-10-2007 03:21 AM
First Triumph (1964 T120) Need Advice Distracto Classic, Vintage & Veteran 6 09-09-2007 05:15 PM
1964 Triumph Bonneville redcelt13 Triumph, Models & Dealers 2 07-11-2006 09:49 PM
Boyer ignition - 1970 Triumph T120 dorkingbonny Classic, Vintage & Veteran 8 06-15-2006 08:06 AM
