Sorry Guys...Jetting - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.com
Old 09-06-2007, 12:05 AM   #1 (permalink)
Favourite Bike: 2005 Bonneville Black
Sorry guys, but i could use your thoughts...
2005 Bonni
AI Removed
Snorkel Removed
Stock Airfilter
JC Whitney Shorty Reverse Cones (EMGO)
125 Main
Stock Pilot (40 i believe)
3.25 Turns Out on the Pilot Screw
The bike does not seem to be running as well as it should and i have heavy POPPING when using the gears to slow down...any thoughts?
(I currently have 115-130 Mains and 42 Pilots ready to install if need be)
Again, sorry for the jetting question..i know these post get old.
2005 Bonni Black; Reverse Cones, Pods, No AI, 145, 42, Thrux Needles, 1.75 Turns Out, Iridium's, EBC Brakes, Speed-Bleeders, and a pile of stock parts.
SCL18 is offline   Reply With Quote
Old 09-06-2007, 12:15 AM   #2 (permalink)
Favourite Bike: 2003 Triumph T100
Sheepdog's Avatar
First check for air leaks at the rubber intake rubbers. The stock clamps do not tighten very well...I used some aftermarket clamps that will snug things down a bit more. Also, I find that the Thruxton needles work a great deal better for my '03 T100 (790cc). They may help yours...use shims to fine tune.
Old 09-06-2007, 12:35 AM   #3 (permalink)
Favourite Bike: 2006 Thruxton Caspian Blu
ocguyocguy's Avatar
Other Motorcycle: H.D. and Honda
Extra Motorcycle: MX, off road, Enduro
Like the other guy said tighten up fittings...the jetting should be OK with the side snorkel removed...alot of bike do that till they are really warmed up after 7 miles or so I think it will not pop very much...
ocguyocguy is offline   Reply With Quote
Old 09-06-2007, 01:17 AM   #4 (permalink)
Favourite Bike: 04 thrux blk(sold)
Gohm's Avatar
Other Motorcycle: 06 klr 650 grn
also check your exhaust, might have a leak where your cans meet the header since you have aftermarket cans. tighten the clamps really well & use sealant. Also check for missing carb caps. 3.25 turns also sounds a wee bit rich too, you could also try backing off a bit to see if that helps.
Be a "weekend warrior" 7 days a week, 365 days a year!
My Photo Album
"A wink is as good as a nod to a blind bat" - MP
Gohm is offline   Reply With Quote
Old 09-06-2007, 03:47 AM   #5 (permalink)
Favourite Bike: 2001 Sky Blue Bonneville
IMHO get rid of the stock filter and fit a freeflow.
Ian
Skyblue62 is offline   Reply With Quote
Old 09-06-2007, 01:33 PM   #6 (permalink)
Thanks,
Here's what i will do...
1st, Check intake connections for "snug'ness" and if need be hit HomeDepot for new/better clamps.
2nd, Check for vacum leaks or missing plugs/caps/hoses.
3rd, Remove headers/mufflers and have exhaust shop weld the connection so that there is only one (1) bolted connection per muffler instead of the two (2) that i currently have.
4th, Use high temp copper silicone gasket and torque down the muffler/header connection for a *air-tight connection.
5th, Dial back to 2.5 Turns out on the Pilot.
After i get the headers welded, should i use/replace the header-engine gaskets or just use the high temp copper silicone gasket?
I'll check back when i'm done and let you guys know if how its running.
What do you guys think? blackstar1965 Club Cafe' 16 12-11-2007 11:42 PM
what do you guys think? motorhead Street Triple Forum 13 12-05-2007 02:16 PM
you guys seen this? jrussell6 Speed Triple Forum 23 02-17-2007 11:58 AM
So What Goes Guys? BannedRider Biker Hang-Out 10 01-16-2007 04:31 AM
You guys were right! 2loose Speed Triple Forum 10 12-11-2005 09:48 PM
