Front left turn signals not flashing - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-05-2007, 11:56 PM   #1 (permalink)
Favourite Bike: 2007 Triumph Bonneville
I went through the threads that discussed turns signal problems and I still need some clarification of what is happening with mine. I just got my bike from shipped (about two weeks since I've seen it). When I switch the turn signal left, the rear left signal blinks really fast and the front left doesn't. I can hear the relay going on and off in sequence with the blink.
I'm not sure if the relay is the problem here or if I just need to replace the bulb. Before I start tackling this, I need some advice on what this could be. Thanks.
t3knoid is offline   Reply With Quote
Old 09-06-2007, 12:07 AM   #2 (permalink)
Just a bulb i believe. When one bulb goes out on most systems, the remaining bulb on that side flashes fast.
Old 09-06-2007, 04:35 AM   #3 (permalink)
Favourite Bike: Modified 2005 T100
Other Motorcycle: 1994 CB750
Mine do that! I just use arm signals at the moment. I think it is not earthing properly
BeastInBlack is offline   Reply With Quote
Old 09-06-2007, 09:08 AM   #4 (permalink)
bonnevillebilly's Avatar
If you can hear the flasher clicking then it's the bulb.
Bill
2001 Bonnie
1976 Bonnie
bonnevillebilly is offline   Reply With Quote
Old 09-06-2007, 11:43 PM   #5 (permalink)
Thanks for all the suggestions. I swapped the left and right bulbs and the right one started behaving the same way....so thankfully it is just the bulb. Although on closer inspection of the bulb, I can't see a break in the filament.
On a related question, is this bulb standard? That is, can I buy an OEM one from an auto shop?
Old 09-07-2007, 12:01 AM   #6 (permalink)
Nevermind...I just found my answer...just googled Osram 5008.
Front Turn Signals... kwajazz Speed Triple Forum 5 12-13-2006 08:39 PM
front turn signals thall912 Speed Triple Forum 12 10-11-2006 08:45 PM
S4 Front Turn Signals B02S4 Triumph SuperSports 2 05-14-2006 05:54 PM
05 front turn signals jradamson Speed Triple Forum 29 11-28-2005 06:11 PM
Front Turn Signals cak03 Sprint Forum 0 07-06-2004 03:52 PM
