09-05-2007, 08:26 PM
Changing oil tomarrow, is this right
You guys got me scared about oil and filters. I got Mobil 1 racing 4T fully synthetic 10w-40 (3 way protection) see photo. Is this right, I hope so cause it was 14.95 a quart. The manual doesn't say where the oil filer hole is, is it the giant crome plug with the big slot on the top off the case? Yes ok, so I'm a little slow... mike
09-05-2007, 08:31 PM
Yes to both. I'd recommend getting a Haynes manual. It's helped dullards like me out quite a bit, plus it's a sweet hardback that looks good on the coffee table.
PS - Don't forget to go real slow when filling up and watch that sight glass closely, these bikes tend to overfill pretty easily and don't take the whole amount usually.
Kansas City, MO
'05 Bonnie Black
09-05-2007, 08:32 PM
Formula Extreme Favourite Bike: '06 Thrux
Posts: 672 Other Motorcycle: '08 Yamaha FJR1300A
yeppers your on the right track, that would be the filler hole. Also its 3.8 litres so hold back .2 litres and return it to the jug. If you change oil every 6000mi, I do, you might need that .2 at around 4500mi. That'll start some mad postings.
Mods:Predators/fork stabilizer/CR-S carbs/RaceTech springs/Berringer 6 pot caliper/Traxxion emulators/LSL sliders/Wave rotors/Pazzo Levers/Ohlins 36PL shocks/port&polished head/street cams/TABII Tank & cowl/IBA #38625 SS1000,BB1500 in Texas
09-05-2007, 08:48 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
And fill the new filter with oil before you attach it.
Marty
09-05-2007, 11:18 PM
Shop around for the oil next time....4T can be had for $9.00 a qt. At that price you might as well by the Triumph oil....Dont overtighten the drain bolt...
01 Bonnie...TORS, BellaCorsa head pipes, Uni, 140mains, two shims, unrestrticted, tack kit, tank pads, chrome front fender, chrome rear thruxton fender, chrome side covers and chain guard, tall sissy bar, tank bag and saddle bags, scrambler gaitors, home made seat bolts and handle bar clock, National Cycle windscreen for the winter
09-05-2007, 11:33 PM
Posts: 1,323 Other Motorcycle: 66 Bonnie Chop
$7.99 at Autozone a few months back (in Maryland). Sometimes Walmart carries it as well.
Al
09-06-2007, 12:51 AM
Formula Extreme Favourite Bike: 2006 Thruxton Caspian Blu
Posts: 715 Other Motorcycle: H.D. and Honda Extra Motorcycle: MX, off road, Enduro
Mobil 1 4MXT is perfect for your bike...Sorry to tell you this but Walmart sells it for $8.00 a quart...you got broomed this time if you paid $14.00! Take the oil back if you want and get your money back...
Regarding the amount of oil you need to add in my opinion...and all the shops I have talked to you do not need to waist time trying to measure .2 quarts...it does not matter...the shops don't do it...your tranny won't know the difference it is a 4 quart system...it will not blow seals...just change the filter, drain and dump in 4 quarts and go riding...most auto parts places and Walmart (Wally World) also sells the correct filters for around $2.50...the wallyworld part number for the Thruxton/Bonnevilles/Scramblers is OILFILTER ST6607...
09-06-2007, 01:01 AM
SuperSport Favourite Bike: T100 black & red
Also the owners guide recommends using a new crush washer each change. The dealer should have them if not, Honda car dealers do. The ID is 14mm and OD is 21mm. The last thread on this most felt if the old washer is in good shape then its not critical to use a new one. But I thought you should know your options.
09-06-2007, 01:43 AM
"And fill the new filter with oil before you attach it" , also moisten the filter o ring with oil.
Dance with the lady with the hole in her stocking
790 Bonnie Black
09-06-2007, 03:02 AM
Posts: 789 Other Motorcycle: Triumph Hurricane Extra Motorcycle: several bsa,s
the correct oil filter wrench can be bought they dont cost much and make the jod easier..
Regards Ron
Hurricane pictured(Harry)
