09-05-2007, 05:16 PM
Team Owner Favourite Bike: 2003 T100
Posts: 5,474 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: 2008 Guzzi 1200 Sport
Are the small plugs on our header pipes for A/F sensors?
Our header pipes each have a removable threaded plug located about 10-12" from the exhaust port. These must have a purpose, presumably to insert a probe that tests for proper air/fuel mixture(??). If that is their purpose, does anyone know of a Lambda-type sensor small enough to thread into these ports? Or of an adaptor that would screw into the header, and permit a larger Lambda sensor to attach here?
Bob
09-05-2007, 06:38 PM
Supersport 600 Favourite Bike: 2007 Thruxton 989
Posts: 180 Other Motorcycle: 2007 1250S Bandit
They are for co monitors, and unfortunately, the lambda sensors have to be in the exhaust stream, so even if you rigged and adapter, it wouldn't work. You have to drill a large enough hole to weld on the lambda sensor bung.
09-05-2007, 06:49 PM
Thanks, Thrux - I was afraid of that. I looked at some Bosch Lambda sensors on the web where the threaded portion appeared to be the size/diameter of spark plug threads.
09-05-2007, 07:37 PM
holes
My guess is that they are for future O2 sensors for emmission control, like autos have now. If Bonne goes EFI next year, Ill bet you see them used!
CAPT D
09-05-2007, 07:38 PM
Exhaust cutouts!
09-05-2007, 09:18 PM
Site Supporter Legend Favourite Bike: 904cc Bonnie w/magwheels
Posts: 11,815 Other Motorcycle: 2005 Yamaha FZ1
it's for 2 tiny turbos!
09-12-2007, 10:54 AM
.... with the boost measured in ounces per sq inch! You're gonna turbo that Bonnieblack, I feel it happening!
Bob
09-12-2007, 10:56 AM
Bob
I think you're right Bob. I just gotta round up a few thousand bones...
