I went to install a new front wheel today and noticed that the hub was missing the rubber seal that goes around the spacer on the caliper side (left side). The spacer does not seat without this seal. The other side, with the smaller spacer does have one.
Is it possible to remove this seal from another wheel and reuse it? If not. What is it called? Where can I get one?
I've had no luck searching for answers so hopefully one of you can help.
I wish I had pics, but I don't.
Thanks!
Thanks!
