turn signal switch has a gremlin - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-05-2007, 01:49 PM   #1 (permalink)
Favourite Bike: 2005 bonneville cafe'd
AJF1134's Avatar
Talking turn signal switch has a gremlin
gave my dnm demn a bath about a week ago, and as always was very careful about getting water in any of the electronics. after i dryed her all off I gave her a once over and realized that none of my turn signals were working. well i began to trouble shoot the problem by blow drying out the switch , checked the fuses shook the wires checkin for a short and nothin...
well a week goes by and still no signals, so I decide to the dealer since she is still under warranty. well last night as i am riding her to a friends house the blinker lights come on but don't blink. i get up this mornin and get ready to drop her off and the blinkers work perfectly.?? happy to have her workin properly, but has anyone ran into this before?
were the electronics still wet?? i live in sacramento where the past week has been 100 degrees + figured that heat would dry out anything.
let me know if youve experienced this type of problem.
AJF1134 is offline   Reply With Quote
Old 09-05-2007, 01:54 PM   #2 (permalink)
I never pay attention to not getting my electronics wet and have yet to run into any problems with the electronics not working. Maybe im just lucky??
xX05bonnieXx is offline   Reply With Quote
Old 09-05-2007, 02:02 PM   #3 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
Sounds like your flasher unit (behind the left side cover) may have been water-logged. Check that area and you might want to apply some dielectric grease to the connectors on the relays in that area also.
Larry
Old 09-05-2007, 02:25 PM   #4 (permalink)
Favourite Bike: 2007 bonnie black
try a spongebath instead.
jfenton is offline   Reply With Quote
Old 09-05-2007, 03:24 PM   #5 (permalink)
Flasher
The flasher and starter relay are prone to getting wet no matter how careful you are when washing. The Dielectric grease is a good suggestion. I also put some electrical tape around the joint between the relay and junction box. You can also put a plastic bag over them while washing. I would put the side cover back on while washing.
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 09-05-2007, 03:27 PM   #6 (permalink)
signals
As said try a sponge bath or better yet "Dry Cleaning". Bonne's donttake to water very well. Dont care much for salt air either! The closest thing my Bonne has cometo a hose is the rare rain shower before you can find cover. I always try to remember where the nearest Bank drive thru's or covered gas pumps are on trips! Water sounds like it was your problem- sealing cnnections is the thing to do. Only elec problem I have had is when I put on the new horn & hooked it bkwds. Blew a fuse. Found out that fuse does the horn turn signals & some other stuff. My 67 AH 3000 had 2 fuses for the entirecar! The british dont change in some ways- more fuses that control bizzare combo's! Nothing dedicated t o1-2 circuits. O well takethegood w/ the bad.
CAPT D
Old 09-05-2007, 06:09 PM   #7 (permalink)
This happened to me last year. After removing the left side cover I saw that the rubber strap holding the flasher relay to the frame had rotted (just like the battery strap!) and the flasher was hanging upside down. In that position it collected and held any water that got in. I pulled it from the socket, blew it dry, replaced it, and used a velcro computer cable strap to hold it to the mount. No problems since. I've recently thought that a half-inch ring cut from a bicycle inner tube might be good for securing the relays. I remember someone also suggested a section of bicycle tube with slots cut in the ends for a battery strap replacement.
Bob
bobmig is offline   Reply With Quote
Old 09-20-2011, 11:28 PM   #8 (permalink)
Favourite Bike: 2004 Triumph Bonneville
flashers won't blink after wash
This is the same problem I've been having. Nice post Bob. Good idea about the inner tube. Thanks!
-Ben
Chauncher is offline   Reply With Quote
Old 09-21-2011, 11:32 AM   #9 (permalink)
Favourite Bike: 2012 Bonneville SE
Lewlew's Avatar
My Bonnie gets rained on all the time uncovered and I ride in the rain fairly often, too. Luckily I have yet to have an issue. I have always grown up with the impression that bikes are fine in the rain, I am pretty diligent about wiping it down and cleaning her up after a good storm. The problem is i live in the city, dont have a garage, and have to rely on alley parking. What effects do you think rain will cause, besides possible premature rusting?
2012 Triumph Bonneville SE
Lewlew is offline   Reply With Quote
Turn signal switch shorts in the rain? Myrddraal Sprint Forum 6 10-10-2011 11:18 AM
Turn Signal Daytona Deliberations 4 10-11-2010 02:35 PM
Repair turn signal switch? kevdude70 Classic, Vintage & Veteran 2 07-24-2007 07:46 AM
Right turn signal out raff Twins Technical Talk 10 05-25-2007 10:33 AM
turn signal? Jacksmack77 Twins Technical Talk 1 04-13-2007 03:23 PM
