Needles on '07America - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 09-05-2007, 12:50 AM   #1 (permalink)
Question Needles on '07America
How do All,
I'm busy buying some parts for my America "upgrade"
I've fitted Staintunes already and ripped the AI.
Next is going to be a Freak Kit with Jetting etc.
My question is : "Can/Should I fit the standard Thruxton Needles in my America?"
(I can not find a set of TBS needles anywhere)
According to Pat's jetting calc, doing this would then require 150 Mains and 45 Pilots for my ellavation. Any comments?
Should I leave the Stock needles and go bigger Mains? Which is better and what would the difference in performance be?
Brent is standing by to ship whatever I may require ...
Thanx in advance!
Do not TRY!
Do, or Do Not...
There is no try.
Saffer is offline   Reply With Quote
Old 09-05-2007, 01:36 AM   #2 (permalink)
not to further your question or start a debate,,but i have a couple concerns with some of your planned changes. i do not have the freak kit but i do have aftermarket carbs that have rendured the airbox useless, problem here as with the freak is it leaves the crank vent open to atmosphere. to counter this i purchased the krank-vent wich is going to set you back another fast 100 dollars plus. also, i highly dougbt bigger mains is an issue because they only are really used when throttle is "WFO". as for needles i also tried many other sets and came up with nothing notable, in the end i decided that the stock cvk carbs are extremely limited in design as to what can be tuned. wich led to the pricy aftermarket carbs purchased. another costly addition. so,, strictly my opinion only,, your going to have to work with shims and jets only to tune to the upgrades as best you can. gas mileage and seamless throttle is a great indicator your carbs are providing proper fuel ratio as well as exhaust pipe color for the novice tuner. with a little practice you can get quite good with these methods. just my thoughts, not to be taken seriously by anyone.
rodtba is offline   Reply With Quote
Old 09-05-2007, 02:03 AM   #3 (permalink)
Thruxton needles oughta be about right. May even be able to shim them, but i think they would likely be good by themselves. i have my airbox still, but it's got a uni filter and the snorkel is gone and the bottom cut out to double the intake area. And in that state with 130 mains the thruxton needles were a bit too rich especially at high revs. Otherwise they were close. So they should be good with the box removed. then you can always experiment with shims, which by the way i would highly recommend. i found the majority of the eyebrow raising gains i got while tuning my bike were from needle/shim changes. TBS needles by the way are very long, and i found with 3 shims the bike ran almost exactly the same as thruxton neeldes with no shims. 3 shims made them the same length as the thrux, and the taper looked similar. i felt the difference was a tiny bit better off the line with the thrux, and a tiny bit stronger midrange with the TBS and 3 shims. otherwise very similar. so yeah, i'd say try the thruxtons once the box is removed.
Old 09-05-2007, 10:06 AM   #4 (permalink)
Favourite Bike: 05 TBA
ErwinM's Avatar
Other Motorcycle: 1997 GT mountian bike :)
Cant you get them fromthe dealer
Erwin
ErwinM is offline   Reply With Quote
Old 09-05-2007, 01:46 PM   #5 (permalink)
Thumbs down Tbs
I'm in the US (Portland) on business and have tried both dealers in town. Nothing. I also tried every dealer back home (South Africa)... Nada!
The dealers back home run with minimal parts/accesories/clothing. Really peeves me. I did however have to buy another huge bag to take stuff home with me!!!
Do not TRY!
Do, or Do Not...
There is no try.
Old 09-05-2007, 02:45 PM   #6 (permalink)
ErwinM's Avatar
How long are you in the states/ only takes a couple of days to get them
Erwin
Old 09-05-2007, 04:38 PM   #7 (permalink)
Leaving
I'm outa here again on Wednesday (12th) next week.
Can you recommend anyone reliable to get them from in such short notice?
Do not TRY!
Do, or Do Not...
There is no try.
Old 09-05-2007, 04:44 PM   #8 (permalink)
ErwinM's Avatar
I bought mine here on the east coast a http://www.jacktrebourmotorcycles.com/. If you give them a call and order it Id be happy to pick it up and mail it to you to SA or they might be able to get it to you by the 12
Erwin
Old 09-05-2007, 08:38 PM   #9 (permalink)
Or palmbeachtriumph.com
I and a number of others have bought from them. But whoever you buy needles from, they may have to order them because most dealers don't stock parts like that.
Old 09-05-2007, 08:43 PM   #10 (permalink)
ErwinM's Avatar
Yup, good folks there also..........
Erwin
Need TBS needles jimmything Twins Talk 13 01-30-2008 07:53 AM
Thruxton needles psasak Twins Technical Talk 11 09-14-2006 10:22 PM
Dynojet needles v. Thruxton needles stu Twins Technical Talk 6 08-17-2006 11:09 PM
Thruxton needles johnsime Twins Technical Talk 4 08-04-2006 12:33 PM
Which needles to get? dave31grant Twins Talk 10 01-19-2006 01:23 PM
