Another Day, Another Leak - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-04-2007, 10:44 PM   #1 (permalink)
Mattrat's Avatar
Walked out of my office, saw a puddle of oil under the bike.
F*(&*&^*$^*&*$%#*!#@$^!^*!!!!!!!!!!!!!!!
4th oil leak in under a year. And this was in a new spot - looked like it was coming from above the oil filter.
Checked the oil level - looked ok so I drove to the dealer...you know, the guys who fixed it last time...and the time before that...and...you get it...
Turns out it was leaking from an electrical switch (neutral indicator?) just above the oil filter.
Dealer's mechanics said they had never seen that one before.
I know I got some hate here last time I bitched about an oil leak (caused by either factory or dealer's over-torquing of the cover bolts) but I'm going to say it now. Last chance. I love the feel and style of this bike, I love the ride, but one more problem and I'm going to be looking for a new bike. Maybe Triumph, maybe not...but My overall impression of this engine so far is that it's a piece of sh*t.
adios, muchachos
Mattrat is offline   Reply With Quote
Old 09-05-2007, 01:19 AM   #2 (permalink)
Favourite Bike: '71 Norton Commando
CommandoRdster's Avatar
Other Motorcycle: '07 Scrambler
Extra Motorcycle: '71 BSA Victor B50MX
Good thing you didn't ride English bikes back in the old days.
Cheers!
Bruce
ANIMAL RESCUE SITE-Please go there and click on the purple button!
CommandoRdster is offline   Reply With Quote
Old 09-05-2007, 06:51 AM   #3 (permalink)
Mattrat's Avatar
You would be incorrect. I did. I expect the leaks and fuse replacement on the old ones. They give the bikes "character"
What I don't expect is that a brand new bike thet is built in "one of the most advanced factories in the world" to have 4 major leaks in the first 5000 miles. I use this bike as my everyday transportation and I need it to work correctly. Hopefully this is the last problem and I'll stop complaining, but I want to put this out there to see if these problems are unique to my bike (I got a lemon?) or common to the 790cc engine.
adios, muchachos
Old 09-05-2007, 07:01 AM   #4 (permalink)
Favourite Bike: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a CR&S Vun
I bought my '04 790ccm this Spring with 4600kms on the clock. No record og oil-leaks. Now it has 14000 on the clock and still no leaks.
Maybe you got a lemon. Maybe the mechanic does something wrong.
Good luck whatever your decision.
'04 T100 Black and White (because it matches a dinner jacket)
904, 813, port&polish, Pieman igniter TORS, rebuilt front (valves, springs, etc), Öhlins shocks, tubeless alu rims, JMC alu swingarm, 520 conversion, Ti nuts and bolts
- Ringer
TB-T100 is online now   Reply With Quote
Old 09-05-2007, 07:03 AM   #5 (permalink)
Favourite Bike: thruxton
hans's Avatar
Other Motorcycle: one is enough but I'd lov
Extra Motorcycle: nah
ok
My 2005 T100 is totally oil tight. Its parked at my house in the same spot and never a hint of oil on the ground! (except when I did an oil change myself and bumped the oil pan after scorching my arm on the exhaust!!)
I had a BSA gold flash in the early 70's (a10) and topping up the oil tank was a weekly job!!
NO-ONE IS COMPLETELY WORTHLESS
THEY CAN ALWAYS SERVE AS A BAD EXAMPLE
vado vestri own via
hans is offline   Reply With Quote
Old 09-05-2007, 07:25 AM   #6 (permalink)
My 2001 has 27K on it and has never leaked a drop. Its sounds like you need a new mechanic...not a new bike. Anything with a gasket can leak...its all in how its repaired.
01 Bonnie...TORS, BellaCorsa head pipes, Uni, 140mains, two shims, unrestrticted, tack kit, tank pads, chrome front fender, chrome rear thruxton fender, chrome side covers and chain guard, tall sissy bar, tank bag and saddle bags, scrambler gaitors, home made seat bolts and handle bar clock, National Cycle windscreen for the winter
AAAANDYK is offline   Reply With Quote
Old 09-05-2007, 08:32 AM   #7 (permalink)
Mattrat...
four leaks would push me to the edge as well. Fortunately, in the brief time I've had my '06 (3-months - 2500 miles) not a drop.
As was said before, if you like the bike, try a new mechanic before you give up on it.
Good luck!
JC
JC
2006 Goodwood: Progressive Front Springs, Works Black Tracker Shocks, TORS, Tach and, of course, Union Jack License Plate Bolts.
Formerly: VTX 1800C
"God must love stupid people; He made a lot of them."
UraniumC is offline   Reply With Quote
Old 09-05-2007, 09:34 AM   #8 (permalink)
Favourite Bike: Definitely my 2007 Black
Hedge's Avatar
Arrow New mechanic
Matt - I feel your pain brother! I suggest as a last attempt to take it to Libby's and see if they can fix it. This way you will now know whether it is the bike or the mechanic and then you can decide your future plans from there.
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 09-05-2007, 12:27 PM   #9 (permalink)
JP06t100's Avatar
Earl Leak
My '06 was leak free thru break in, (dealer serviced it) then @ 3,000 I changed the oil myself & within 48 hours the valve cover gasket started leaking, as did the sensor area just rear of the oil filter. Dealer replaced the gasket & told me I was a bit over filled on the oil. When I changed it I filled it just shy of the upper line on the sight glass. Shop mechanic said as long as it shows in the glass you are good. (On the center stand on level ground I should add.) It seems plausible the higher pressure would seek the path of least resistance, and since that time I've taken the mechanics word and filled the oil closer to the lower indicated line, I keep an eye on it and nothing leaks & the oil level remains constant. I have 10,000 miles now. Related?!? Coincidence?!? I don't know but otherwise trouble free. Good Luck!
J.P.
Frank: "Ughh, I bet you'll never guess what I had to do!"
Ozzy: "Umm,... Did you have to drink some chuck?"
JP06t100 is offline   Reply With Quote
Old 09-05-2007, 12:33 PM   #10 (permalink)
oil leaks
My Bonnie hasnt leaked yet. I changed the oil at 5300 miles, and now at 6000 there are still no sign of leaks. still get a little of the cosmoline from the head on real hot days, but not oil leaks.
cliff
2006 Bonnie Black
1980 Yamaha xs650 sold 4-30-2011
alfacliff is offline   Reply With Quote
Day 1 and Day 2 with new bike. Moochy Club Cafe' 20 09-11-2007 12:03 AM
Good day, bad day.....'02 RS owners please chime in Iggy762 Sprint Forum 4 06-11-2007 04:48 AM
Look for a leak maybe? midliferider Hinckley Classic Triples 6 06-01-2007 07:44 PM
Name this *possible* leak Iggy762 Sprint Forum 10 04-20-2007 07:46 AM
bad day good day anglen Twins Technical Talk 2 07-02-2006 11:06 PM
