Originally Posted by Anchorbend
Ijust went through starter issues, although different since my starter kept winding after the bike started. Since you could jump the posts and it started it sounds like a solenoid but it could be a relay. You can get a relay at Advance, Autozone etc. I posted the numbers in this link. A lot od good advice in the thread below.
http://forums.delphiforums.com/new_b...s/?msg=15665.1
Go to Maintenance and Repairs menu and look at "Starter Issues"
Good luck
Anchorbend
Did your problem with the starter turn out to be the starter relay?
The starter relay is also the headlight cut out relay. It cuts power
to the lights and sends it to the starter solenoid wile the starter button
is being pushed. Your problem sounds like the starter/light cutout relay
was stuck in the closed position sending constant power to the solenoid.
My problem is
The starter relay/light cutout relay and the solenoid both checked out OK.
There has to be a short some were in the lighting circuit.
Right now every thing is Ok. I will just have to wait till it happens again
and hope I can trace it down.
Thanks for the link there was some good stuff over there.
Bill
