Old 09-02-2007   #1 (permalink)
Favorite Bike: Scorched Yellow/Black T10
Chain Life?
How long shold a chain last, with moderate (occassional hooning) riding habits?
I've noticed mine needs adjusting more frequently and I'm wondering if i should replace it?
Thanx for any advise.You guys rock!
It's a nice day for a ride....
Moggy is offline   Reply With Quote
Old 09-02-2007   #2 (permalink)
Your owners' manual shows how to measure it for a replacement check [ not to be confused with a tension check]. I would think this to be more reliable than how many miles are on it, as the miles may have been under varying conditions such as too tight/loose, aggressive riding, poor lubrication, etc. I have heard these new chains last quite awhile compared to the old ones, however.
davidc is offline   Reply With Quote
Old 09-02-2007   #3 (permalink)
Favorite Bike: Modified 2005 T100
Other Motorcycle: 1994 CB750
16,000 miles, only on the 2nd adjustment notch, only needs adjusting probably once every 400 miles maybe more depending on the type of riding.
BeastInBlack is offline   Reply With Quote
Old 09-02-2007   #4 (permalink)
Favorite Bike: 05 Bonneville T100 B/W
wenzel850's Avatar
12k miles, the chain has been adjusted twice. I'm not the best when it comes to chain maintenance, but I'm getting better. Cleaned and lubed about every 600-700 miles. I use DuPont Teflon Multi-Spray.
Quentin
"01-20-2009 I can't wait"
wenzel850 is offline   Reply With Quote
Old 09-02-2007   #5 (permalink)
Chain
Iguess it depends on how well youcare for it? My bud got 38000 mi &just had to replace iit. They sure make em better thesedays!! In the old days they would last amybe 8-9000 mi?
CAPT D
CAPTDON is online now   Reply With Quote
Old 09-02-2007   #6 (permalink)
I got 25K out of the chain...and I was well past the last adjustment. Two to three lubes a year with one adjustment every 4K when I change the oil. Chain life depends on the environment, lube and adjustments. Too tight ...this stretches the chain quickly and puts unnescessary load on the transmission bearings and seals at the sprocket.
AAAANDYK is offline   Reply With Quote
Old 09-02-2007   #7 (permalink)
RonD's Avatar
Other Motorcycle: Triumph Hurricane
Extra Motorcycle: several bsa,s
with chains i would expect at least 30,000 klms and up if its well cared for..
Regards Ron
Hurricane pictured(Harry)
RonD is offline   Reply With Quote
Old 09-03-2007   #8 (permalink)
At 7500 miles, I lube every 1000 miles or so, and it's had no real adjustment yet after the 500-mile service. I've had the wheel off a couple times, but the chain went back where it was, directly on one of the alignment marks. I leave it on the slack side of the spec, as recommended by the Rats here.
I expect at least another 7500 miles, if not much more.
More frequent lube equals more mess, and I'm not convinced that it's necessary. The chain moves freely and looks good, as do the sprockets.
Marty
Old 09-03-2007   #9 (permalink)
I would never dream of lubing less often than every 500 miles
Old 09-03-2007   #10 (permalink)
Lube chains every 500 miles? That like once every two weeks....I dont even wash the bike that much
01 Bonnie...TORS, BellaCorsa head pipes, Uni, 140mains, two shims, unrestrticted, tack kit, tank pads, chrome front fender, chrome rear thruxton fender, chrome side covers and chain guard, tall sissy bar, tank bag and saddle bags, scrambler gaitors, home made seat bolts and handle bar clock, National Cycle windscreen for the winter
ST Chain Life Philfart Sprint Forum 23 04-24-2008 11:29 AM
Chain Life (here we go again) jttrout Twins Talk 11 04-27-2006 08:42 AM
Chain life. blacktiger Tiger Chat 2 10-23-2005 01:44 PM
Chain Life pigpen955 Tiger Workshop 33 03-20-2005 04:00 PM
Chain life - what do you get? harum-scarum Tiger Chat 25 08-18-2004 07:56 AM
