BikeBandit
Old 08-31-2007   #1 (permalink)
pz1
Favorite Bike: 2005 bonnie black
pz1's Avatar
Smile air filter plate
it looks to me that you could enlarge the hole that the snorkle fits in by about 3/8", would that have the same results as a bellmouth? guess i'm being cheap. thanks for everybody's input. will most likely buy the nh bellmouth.
pz1 is offline   Reply With Quote
Old 08-31-2007   #2 (permalink)
Favorite Bike: Triumph Scrambler '06
Make a search on the forum on bellmouth first. There is a Polaris snowmobile part that you can use instead that's way cheaper than the NH part. There's also some posts regarding if the bellmouth does much good anyway. (don't ask me I don't know...)
Cheers!
Mallkolm is offline   Reply With Quote
Old 08-31-2007   #3 (permalink)
Favorite Bike: duh! My '07 Black!
baby steps
You know, you *could* just pull the snorkle and stop there. That will let the extra air in. The bellmouth is just supposed to "smooth" the air that rushes into that opening - which doesn't make sense to me because the next thing all that smooth air is going to do is slam into the filter and then swirl around through the hole in the restrictor plate. Someone posted a while back that the drag coefficient of the bellmouth vs. the raw opening vs. the size of the opening was such that the impact was going to be on the order of a couple percent of the airflow. So, you could just skip the bellmouth altogether (I did).
On the other hand, there is definitely a certain "rushing" sound of air into that big hole. Maybe the bellmouth diminishes that a bit, I dunno.
Gone to greener pastures.
BlueJ is offline   Reply With Quote
Secondary Air Injection plate install Part I TrackerOldGuy Speed Triple Forum 29 07-10-2008 10:26 AM
air filter wildchild Twins Technical Talk 1 06-08-2007 10:04 PM
uni verses KandN air filter air flow rays323929 Twins Technical Talk 3 01-31-2007 04:09 PM
k&n air filter for a 05 S3 aaronb_dsn Speed Triple Forum 14 01-26-2006 09:47 PM
K&N Air Filter??????? ken750f Speed Triple Forum 17 08-19-2005 06:55 PM
