My headers are painted with BBQ black spray paint and it holds up just fine.
I scuffed the chrome with a 60 or 800 grit sanding block then laid down one coat of the BBQ paint, and let it dry out in the sun for a couple hours. Then scuffed the paint with 0000 steel wool, and then 3-4 more coats of paint with 0000 steel wool after each coat (and after the last coat too).
It's held up well and looks good, just keep gasoline off it!
Removing headers: Obviously take the mufflers off first, then you may have to remove the footpegs (can't remember) then there are 2 bolts under the footpegs holding the headers to the frame. There are 2 nuts holding the headers to the studs in the head, and the clamp that holds the 2 crossover pipes together. My crossover pipes were a BEE-YOTCH to get separated. Lots of sweat and swearing and yanking.
