Old 08-29-2007   #1 (permalink)
Newbie
Valve adjustment, clearances well over the limit
I have a T100 with 10500 miles on it, doing the service myself, valve adjustment is the only thing that bothers me. I measured the clearances today and all 8 of them were over the limit. These are the readings I got:
Exhaust Left to Right: 0.38mm 0.40 0.42 0.38
Intake Left to Right: 0.28mm 0.28 0.25 0.23
The recommended figures(haynes manual) are: Exhaust 0.25-0.30, Intake 0.15-0.20mm.
Is there something wrong with the valves, shims or my feeler gauges :-)?
What happens if I don't adjust the valves? What are the effects of excessive valve clearance?
My bike backfires a lot( BTW, I have Norman Hyde exhausts fitted with matching jets ) and the MPG is disappointing, 33-35MPG in the city. Is there a connection?
Any help will be greatly appreciated.
fridaylover is offline   Reply With Quote
Old 08-29-2007   #2 (permalink)
Favorite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
raproe's Avatar
Those are reasonable numbers. When I adjusted my valves at 12000 miles I started out with:
Exhaust Left to Right: 0.36mm, 0.38, 0.36, and 0.46 (yes 0.46!)
Intake Left to Right: 0.25mm, 0.25, 0.2 and 0.25
If you don't adjust the loose valves you get more noise (my engine got a whole lot quieter when I got that .46 exhaust back in line), you reduce the duration the valves stay open (because the cam has to rotate more to pick up the extra slack), and you put more load on the cam and valve train (because you miss some of the acceleration/deceleration ramp on the cam).
The disappointing MPG probably isn't because of the valves but, if you fix them, you can eliminate that issue.
Rich
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
raproe is offline   Reply With Quote
Old 08-29-2007   #3 (permalink)
Retired Legend
sweatmachine's Avatar
not to mention pick up a few hp!
Old 08-29-2007   #4 (permalink)
valves
They dont sound too bad to me either? I will adjust wnen the noise getstoo much rythem. My bud w/ BA has exhaust on the left w/ a good rap rythm- both valves. The rest sound ok. Its time then. Dont know when he will get to it?
Still ride all the time. Not too loud - just constant. Doesnt seem to bother him much?? Got 10500mi on it.
CAPT D
Old 08-29-2007   #5 (permalink)
The hardest part of the whole process is getting your hands on the right shims. You may get lucky and get to swap some. I have both the Haynes manual and the Triumph and it helped to be able to look at the pics in the Hayne's as well.
Take it slowly and methodically, & search the wiki for the Shim Calculator someone wrote, worked real well.
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 08-29-2007   #6 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
Here's my old/new clearance figures. Although Triumph offers shims in .025mm increments, it is also possible to use shims from Honda, Yamaha, etc, that are the same diameter as those used by Triumph.
Since I already had the cams out, I didn't feel like waiting 3-5 days on Triumph shims, so I lived with the resulting clearanges using shims in .05mm increments.
Next time, it'll be easier, because I recorded the thickness of the shims I installed. The valves held their clearances well, in my opinion, for an engine with almost 22k on the odometer. I'd have to think that some of the guys on the Triumph assembly line use shims closer to the tight end of the spec than others.
T100 Exhaust Valves
Current Clearance 0.33 0.31 0.31 0.31
Current Shim 2.75 2.82 2.82 2.85
New Shim 2.8 2.85 2.85 2.9
Calculated Clear 0.28 0.28 0.28 0.26
Actual Clearance 0.28 0.28 0.28 0.28
T100 Intake Valves
Current Clearance 0.254 0.26 0.254 0.2
Current Shim 2.8 2.82 2.86 2.9
New Shim 2.9 2.9 2.95 2.95
Calculated Clear 0.154 0.18 0.164 0.15
Actual Clearance 0.154 0.21 0.18 0.18
Bob
Old 08-29-2007   #7 (permalink)
Cool Shims
I had my shims done by my dealer at 12.500 mi.. He used 8 shims which were all loose. No telling how close they were coming from the factory.
You've never rode until you've been throwed.
Anchorbend is offline   Reply With Quote
Old 08-30-2007   #8 (permalink)
raproe's Avatar
Originally Posted by Anchorbend View Post
...No telling how close they were coming from the factory.
I suspect Triumph lets a few get through. When I had the 500 mile check done, the dealer said that one exhaust was already pretty loose and would need to be fixed at 12k. I suspect it was the 0.46 one. Hopefully that one will be settle in and still be OK at 24000 miles since it required the largest shim Triumph has to bring it into spec.
Rich
Old 10-18-2007   #9 (permalink)
Favorite Bike: all of them
Other Motorcycle: Thruxton, spd Triple
Extra Motorcycle: T140, BSA B50
loose valves?
how do valve clearances grow or loosen? in 40 years of working on bikes I have never seen a healthy engine increase its valve clearances; they always tighten as the valve recedes into the valve seat
drlapo is offline   Reply With Quote
Old 10-18-2007   #10 (permalink)
Favorite Bike: '05 Thrux
Boddington's Avatar
Valves and seats wear usually together depending upon materials, and tighten tolerances. (normal wear and tear of an engine) Going loose vs tight is quite a mystery to me too.
Titatium valves had issues on some dirt bikes. Husky and Honda had these issues, due to using titatium and steel seats. No one knows why Yamaha doesn't have this issue, but they say it could be because of their 5 valve technology putting less stress on the valves.
Our Bonnies are running stainless steel valves? Anyone know?
K&N's, British Custom's, shimmed, drilled, 140/42's
Boddington is offline   Reply With Quote
Valve Clearances Tassie_Tiger Tiger Workshop 1 11-12-2007 02:38 PM
Valve clearances GreenGoblin Trophy 8 02-21-2007 08:01 PM
Valve Clearances fivehundo Daytona Deliberations 4 02-20-2007 07:23 PM
Just checked valve clearances - not waaay off! Any Valve Experts out there? ohiorider Twins Technical Talk 6 07-28-2006 10:37 PM
Valve Clearances cowboyfitter Hinckley Classic Triples 4 07-23-2006 06:22 PM
