AdvanstarMotorcycleShowsMotorcycle.comBikeBandit
Old 08-26-2007   #1 (permalink)
My dyno run yesterday
has opened up a can of mental whoopass for me regarding the air/fuel ratio.The AFR was rich across the board and very rich around 3500.But as the graph indicates,this is where the torque started to bulge upward. Is the torque a result of the richness? I plan to remove at least one of the shims on the Thrux needles to lean it out a bit in that area,but without access to the dyno again,I don`t want to chance losing that midrange surge.I also have the next smallest main jets [117.5 in this case]which could lean out the upper rpms,but how critical is it to overall performance to try to reach the magic 13.2AFR? I`m sure the entire AFR could or would change if I simply changed the air filter or rode at a higher elavation,so I`d like to stay a bit on the rich side.Opinions?
Old 08-26-2007   #2 (permalink)
bonnieblackinfl's Avatar
Follow the results, if it likes it richer...go with it. I would go richer on the main, apparently she likes it fat! For giggles, go with the 2 steps up on the main for the next dyno, you can always go back!
Greg
bonnieblackinfl is offline   Reply With Quote
Old 08-26-2007   #3 (permalink)
Take it to another Dyno first, it might not be calibrated as it should
jojje1963 is offline   Reply With Quote
Old 08-26-2007   #4 (permalink)
Thanks Jojie. Not sure when the next dyno run might be,but I`ll do it again for sure.I do know that the guy who tested 3 bikes before me was riding a Kawi cruiser/motorhome and had just come from his dealer with a brand new FI map and A/F test to get on the dyno. His couch registered a near straight line 13.2,except for a small hiccup just off idle.He had the earlier printout in hand and they were nearly identical.He did put up almost 98lb/ft max but almost the same low 70hp as the wee Bonnie,whose entire displacement was less than one of his water cooled jugs.
Old 08-26-2007   #5 (permalink)
Well,I removed one shim,and as expected,no great change to rideability.It seems to pull a very,very little bit cleaner at low revs,but no harder.The idle did increase a couple hundred rpm though.Guess I`ll try it that way for a few weeks and concentrate on testing that new Mustang solo seat. LOL
dyno run admiral crowe Twins Technical Talk 3 01-10-2008 06:25 PM
First Dyno Run? flatso Twins Technical Talk 5 04-08-2007 10:05 AM
Big Man Run- anyone there yesterday? Rubbus Speed Triple Forum 0 08-06-2006 08:24 AM
Dyno run pete Triumph SuperSports 7 05-25-2006 05:30 AM
Dyno run...... FattRat Twins Talk 7 09-19-2005 06:57 AM
