Urgent to chris and Ian from webonnielad
First of all apologiseis to everyone for posting this here, but i'm trying to save these guys a couple of hundered miles between em.
Sorry guys I have a big time and intermmitent problem with my ignition circuit on the bonnie.
I wont be able to make Wessons tommorow.
I got to get this checked out before I can use the bike again.
But please keep in touch.
I've already pm'd texted and e-mailed you so hopefuly you'll see this.
All the best
jon
