Old 08-24-2007   #1 (permalink)
Favorite Bike: 2001 Sky Blue Bonneville
Smile Carb Diaphram
Decided to install thruxton needles with the tank still on and full of fuel, took the tops of and removed the diaphram/piston assembly - being careful not to put a hole in it. Changed needle put diaphram back in - what a pig to re-seat the diapham, it's slightly to big and keeps popping back out. Anyhow I left the job to another day, when i came back to it THE DIAPHRAM HAD SEATED ITSELF!!!! put the top back on and jobs a good un!
Patience is a wonderful thing!
Ian
Ian
Skyblue62 is offline   Reply With Quote
Old 08-24-2007   #2 (permalink)
Retired Legend
sweatmachine's Avatar
I have heard of people having a tough time with this job, and I've had mine out at least a dozen times and they have never once given me grief.
(cam chains on the other hand....whew!)
Old 08-24-2007   #3 (permalink)
cw
Favorite Bike: 2006 Scrambler
Only one of mine has trouble seating. The cap is tapered so it'll push the diaphram into the groove on install.
Ian
cw is offline   Reply With Quote
Old 08-24-2007   #4 (permalink)
webonnielad's Avatar
+1 to sweat & +1 to patience, us Brits excel at patience, the way my bike is at the moment I have to.
webonnielad is offline   Reply With Quote
Carb Help Derby Boy Twins Technical Talk 16 01-29-2008 09:21 PM
dual carb to single carb skech Classic, Vintage & Veteran 9 06-10-2006 06:29 PM
Carb Mixture Adjustment/Carb Balancing pweitz Twins Talk 7 03-13-2006 12:54 AM
Carb Mixture/Carb Balancing pweitz Twins Talk 7 02-08-2006 09:31 PM
any tricks to seating the carb diaphram? dazco Twins Talk 16 12-06-2005 08:14 AM
