Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 08-24-2007   #1 (permalink)
checking mixture?
hi guys, i was just wondering how you guys check your mixture settings to know if your running lean or rich, other than looking at the plugs that is
the way i was taught was to check it on cars was to mist some carb cleaner over the carb and when it bogged down it was rich and when it raced it was lean then find a happy medium
would that work with the air box in place?
fattony23 is offline   Reply With Quote
Old 08-24-2007   #2 (permalink)
Wouldnt work with air box, as its a common air feed to 2 carbs. not sure if it works at all, tell you the truth I have not heard of that one.
I use the plugs, seat of the pants feel, and finally a dyno check to verify my settings(or not)
Also, I know by the pilot jet, and how many turns out the pilot screw is, about where it is, in the lean to rich area.
What are you setting up, maybe I could give you a baseline
G
I just wanted to ride
Old 08-25-2007   #3 (permalink)
Favorite Bike: 2003 Triumph T100
The way I did it with my old Beemer was to warm up the motor, disconnect one plug, and bring up the idle until the one cylinder would stay lit on it's own. Then screw the idle mixture screw in and then out until you find the happy medium between a high idle and an rpm drop. Once you're satisfied, switch the leads and do the other side. Once both are done, reconnect both spark plug leads and adjust your idle to around 1100 rpms. This will get you right where you need to be...
Old 08-25-2007   #4 (permalink)
but dont do that on a bonny.....
Old 08-26-2007   #5 (permalink)
Why not, Geoff?
Old 08-26-2007   #6 (permalink)
stu
Favorite Bike: 1952 Vincent Black Shadow
Other Motorcycle: 2002 Bonny
Extra Motorcycle: 2002 Sprint ST
Running with a plug wire disconnected will wreck the igniter, but you can hook it up to a spare plug and ground it to the motor securely
Stu
TORs, NARK, thruxton needles, 140mains.40 pilots 2.75 turns out, procom igniter, 17T
stu is offline   Reply With Quote
Old 08-26-2007   #7 (permalink)
Did not know, Stu. Thanks for the insight...
FNG checking in. kludge Sprint Forum 8 06-29-2007 10:28 AM
checking interest FuryFour Triumph SuperSports 11 05-16-2007 10:25 PM
New member checking in... Bhakti-rider Twins Talk 7 12-07-2005 07:50 PM
Checking in zore Speed Triple Forum 0 08-07-2005 11:22 AM
Checking In BanditSteve Tiger Chat 10 03-28-2005 10:02 AM
