2007 Bonneville T-100
I stopped by a local hardware store and picked up 2 (12m X 1.25 - 25), you may have to shave these bolts down a bit. Also take a cutting tool and put 2 slits in the head of the bolts so they are easier to wrench down. You will also need to pick up a 3/4 inch plug for the air box. The last thing you will need is a 1/8 inch rubber nipple to plug up the line that used to go into the carb. Total cost for this was around $10 US. Whole process for me took about an hour. I hope this helps out
