Stupid Tire Problem - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 08-22-2007, 11:47 AM   #1 (permalink)
Favourite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Stupid Tire Problem
So my rear tire has some strange issue right now - I don't seem to be able to get the pin in the valve stem fully compressed with my pump, as it fights me when I try to pump it up. My tire's down quite a bit on pressure (30psi) so I want to get it fixed before it gets so low I can't ride. Front tire's fine, bicycle tires are fine and scooter and car tires are fine, so I know it's the tire, not the pump.
The pump has a built-in pressure gauge, which, when the hose is properly locked onto the valve stem, shows 0 psi until I try to pump it, then it shoots way up and slowly settles back down to the tire's pressure - about 30 psi. My theory is that it's not compressing the pin enough to fully open the valve, but that it is compressing somewhat, so the built-up pressure in the hose when I pump is enough to force the air into the partially-open valve, but it takes much longer than normal.
Ideas? What do I do about it? The bike *is* under warranty but the dealer is in Lakeville and is also slow (several-day turnaround on anything) and I work on my own stuff so I'd rather just fix it.
2005 Aegean Blue Bonneville - Intiminators and Thruxton preload adjusters up front, Ikon 7613s in the back, otherwise stock
2012 Azzurro Fiat 500 Sport
lindsayt is offline   Reply With Quote
Old 08-22-2007, 12:07 PM   #2 (permalink)
Favourite Bike: Thruxton
I think you'd be well served to get a small power air pump. I bought a small Sears mode - no holding tank, just air pressure. With cars, bike, and the motorcycle, I use it all the time. And, I might add, my rear tire on the Triumph often needs air.
Check a power pump out.
davidc is offline   Reply With Quote
Old 08-22-2007, 12:08 PM   #3 (permalink)
grayghost's Avatar
Smile
Try a different pump??? Maybe the Triumph OEM tubes Schrader valve "pin" doesn't like the pump you are using. Even a bicycle hand pump would only take a few minutes and "elbow grease" to adjust the pressure.
" My bike pulls to the left......or the right....depending on what side of the road the Tim Hortons is on"
grayghost is offline   Reply With Quote
Old 08-22-2007, 12:16 PM   #4 (permalink)
Favourite Bike: '67 Rickmann Metisse
dkreidel's Avatar
Other Motorcycle: first bike: '64 Yamaha 80
Extra Motorcycle: Wish I'd kept: 69 Trident
I had the same problem - rear tire too! I had to buy a new tire chuck and it (barely) pushed the valve stem down far enough to fill the tire. I have never seen this before in many, many years of putting air in tires!!
Dick
'09 T100 50th Anniversary- Togas, Hagons, PC V
'09 T100 green/white- Togas; PC III
'07 T100 tang/opal- Togas, Hagons, Sun rims (18" rear)
'06 Scrambler blue/white - Arrow 2>1; Sun rims 19" F&R, Maxxis DTR
'68 T120R - original owner
dkreidel is offline   Reply With Quote
Old 08-22-2007, 12:16 PM   #5 (permalink)
doogin's Avatar
Lindsyat, for what it's worth, I have a cheap electric air pump with built-in pressure gauge. It's gauge shows easily 8psi over what a pencil type gauge shows. Make sure the valve stem is screwed in all the way. How about buying a valve stem core from a parts store.
Dance with the lady with the hole in her stocking
790 Bonnie Black
doogin is offline   Reply With Quote
Old 08-22-2007, 02:12 PM   #6 (permalink)
Favourite Bike: 2001 Sky Blue Bonneville
I'd agree with Doogin - get a new valve core
Ian
Skyblue62 is offline   Reply With Quote
Old 08-22-2007, 02:50 PM   #7 (permalink)
Favourite Bike: 2004 Thruxton
Change the valve core.
BLKTHRUX is offline   Reply With Quote
Old 08-22-2007, 03:06 PM   #8 (permalink)
tire
My bud & I were ridin. His fttire was rweal low. Tried to fill @ station. nogo. Turns out there was a little tiny O-ring in thevalve stem that kept the air from goin in the titre. Took it out & no problem. Dont know why it was there but it isnt any more & all is well THE END
CAPT D
Old 08-22-2007, 09:37 PM   #9 (permalink)
HiVel's Avatar
I had to buy a new chuck and a set of new "guts" (Schrader valves) for the tires. seems like the ones that came on the bike were not very good.
Cheap fix anyhow.
2007 Tiger "Old Blue"
2004 Thruxton "Big Red"
2006 Sprint ST ABS "The Blue COW"
HiVel is offline   Reply With Quote
Old 08-22-2007, 10:03 PM   #10 (permalink)
Yeah, a new valve might do it. My notion on a pump other than a bike pump was purely out of the need all owners of motor vehicles have, to maintain air pressure for a number good of reasons. Of course a new pump will not fix a faulty tire. I guess I take too much for granted as to who reads my posts.
Michelin Anakee Scrambler tire problem in Belpre,OH robpassman Twins Talk 5 05-09-2007 08:19 PM
Probably a pretty stupid tire question jcline8 Twins Technical Talk 11 03-02-2007 05:29 PM
Another Stupid Tire Thread. Yak Triumph SuperSports 7 08-18-2006 12:41 PM
2 stupid tire questions tnsen Classic, Vintage & Veteran 19 04-19-2005 05:39 AM
Seems like a Tire Problem to me Hinckley Classic Triples 3 04-20-2004 02:01 PM
