08-20-2007, 06:16 PM
Team Owner Favourite Bike: 2003 T100
Posts: 5,474 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: 2008 Guzzi 1200 Sport
Source for metric feeler gauges - doing valve adjustment
Has anyone found a source for metric feeler blades in increments of .01mm (.15mm, .16mm, .17mm, etc?). I found a set on the web that comes with loose blades, but I'd like to find something locally.
I'm starting on the valve adjustment, and I'd like to use more accurate feeler gauges. The best I have in my toolbox are in increments of .001" (001, 002, 003, etc), but that makes for some pretty big jumps from a metric standpoint, especially when trying to get the valves spot on. For example:
.006" = .152mm
.007" = .178mm
.008" = .203mm
.009" = .229mm
.010" = .254mm
Maybe I'm being too particular, and can get close enough with the gauges I already have. It's obvious that all my valves are loose. All intakes are approx .254mm, and exhausts are at a loose .30mm. So going .050 thicker on each the exhausts and a bit more on the intakes should bring them within spec. No wonder she was starting to sound like an old Triumph from back in the day. Better loose than tight, anyway.
Any thoughts?
Bob
08-20-2007, 07:11 PM
A feeler gauge set I have shows both measurements on the same blades.
-Ben
http://www.bendavanza.com
08-20-2007, 07:26 PM
The metric measurements, as you noted, are much finer. and the valves have really only a pretty small window of correctness. I bought a snap-on metric feeler guage that does nicely, for about 10 bucks
G
I just wanted to ride
SuperStock Favourite Bike: '06 T100
You can do it with standard feelers no problem. You just have to do more converting.
The inlet valves are .15-.20 mm (.006"-.008") and the exhaust valves are .25-.30 mm (.010"-.012") so just aim for the middle.
There's no need to get any more accurate than that since valve shims only come in .025 mm increments. (.001")
Good luck with 'em.
Some people are a lot like Slinkys.
Not really good for anything, but bring a smile to your face when you push them down the stairs.
08-20-2007, 09:14 PM
Thanks all - the Snap On is something I'll check into, Geoff. I could have the BMW shop's mechanic order it for me off the Snap On truck. I'll probably shoot for the mid-range, between min and max this time (good point about the available shims, Rick)
I'm still torn as to whether to experiment by changing the cam timing one tooth (one tooth advance for exhaust - one tooth retard for intake) I've run this past several folks on this forum, including SCC Bonneville and Jojje, who have already done this, and reported improved lower-end torque.
That decision will come as the cams are replaced. Aside from the fact that the 790 cams have slightly longer duration, this change would make the valve overlap (the period when intake and exhaust are both slightly open together) almost like the 865 engine's overlap, that is, not as great as the stock 790 timing.
If I do this, I'll provide documentation as well as before and after dyno information. As a matter of fact, I already have a slide set prepared that shows stock and modified cam timing. All that remains is to have the "after" dyno run done, and finalize a dyno graph showing before and after.
One tooth doesn't sound like much, but it equals 15 degrees of crank rotation, per Jojje.
Bob
08-20-2007, 09:20 PM
Site Supporter Legend Favourite Bike: 904cc Bonnie w/magwheels
Posts: 11,815 Other Motorcycle: 2005 Yamaha FZ1
hey Bob, want some more torque for free? Want to trade cams?
I'm only 1/2 kidding...
08-20-2007, 09:38 PM
Uhhhhhh .... Sweat, think I'll hang on to the 790 cams. It appears I can achieve 865 type cam timing with minor change of one tooth (as previously described).
BTW - has anyone ever been able to pull any info re timing, lift, duration, from the company in New Zealand (or Oz) that makes the aftermarket cams for Bonnies?
Bob
08-20-2007, 10:48 PM
Site Supporter Moto Grand Prix Favourite Bike: '98 Thunderbird Sport
Posts: 2,584 Other Motorcycle: '06 Husqvarna TE 610 Extra Motorcycle: '95 TBird - Project
I found my Metric Feeler Gauges at PEP Boys.
I guess they have stores in Ohio??
Cheers,Denny
08-20-2007, 11:02 PM
I am still lookiing for metric drill bits!
2007 Tiger "Old Blue"
2004 Thruxton "Big Red"
2006 Sprint ST ABS "The Blue COW"
08-20-2007, 11:04 PM
And a set of JIS screwdrivers. These are like Phillips head but are Diffferent -"Japanese Industrial Standard". Any body got a source for these and the metric drill bits?? HELP!
