» Links |
08-19-2007
#11 (permalink)
Formula Extreme Favorite Bike: 05 T100
Posts: 619 Other Motorcycle: Don't need another one!
Originally Posted by lucky23
paul, what are the symptoms to look for if it IS running rich/lean on the top rev range?
Accelerate hard from about 5000rpm with the throttle wide open and then ease off the throttle slightly. If the bike momentarily pulls harder before slowing then that is a sign that you're lean and your main jets are too small. The descriptions I have seen of rich running are not as clear cut, but if the bike pulls harder when cold than when it has thoroughly warmed up, you could be running rich. But then I don't thrash my bike as a matter of principle until it has warmed up, so I wouldn't be able to tell!
Paul.
Herts. UK
Opal & Tangerine 05 T100 (865cc)
(Previously Ducati Monster S4 and numerous UJMs)
#12 (permalink)
Formula Extreme Favorite Bike: 1966 Bonnie
Posts: 942 Other Motorcycle: Malvern Star
If you open the throttle all the way and the engine surges then picks up revs your mains are too big,if your bike revs straight out then surges your mains are too small,if it rolls on cleanly and revs right out then your pretty close to spot on.Just make sure your on a empty road when you try.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
08-19-2007
#13 (permalink)
Super Sidecars Favorite Bike: 2006 Triumph Bonnie
cool. i think i'm good! i removed the AI, drilled out the rear baffles and rejetted to 112s, 2.5 turns out on the mixture. seems to run good...
08-19-2007
#14 (permalink)
I believe I answered your question. if you are looking for someone to justify your not doing anything, then dont. the bike will be fine.
if you want it to run better, then rejet.
G
I just wanted to ride
08-19-2007
#15 (permalink)
"If you open the throttle all the way and the engine surges then picks up revs your mains are too big,if your bike revs straight out then surges your mains are too small,if it rolls on cleanly and revs right out then your pretty close to spot on.Just make sure your on a empty road when you try."
i don't mean to hijack the thread, but what exactly do you mean by surge? is the surge caused by too little or too much gas coming through the jet and then mixing with the air?
08-20-2007
#16 (permalink)
Not really. In the original post there is a line in bold. That, and the sentence that followed it constituted my question.
Yes, I'm a lazy slob and I'd rather not screw with the carbs. But my question was if anyone had slipped these mufflers on and neglected to change the jets. And if so... what happened.
There has been alot of great information posted about good results achieved by rejetting. I know it sounds like I'm picking nits here, but that wasn't exactly my question.
'07 Bonnie T-100 :D
Have owned about 20 motorcycles, Iron Butt Association member, Motorcycle Mechanics Institute graduate.... that and $3 will buy me a cup of coffee at Starbucks
08-20-2007
#17 (permalink)
and I answered, it will run ok. but better if you re-jet. I know this because I ran my tors with no rejet for a week or 2.
now go do what you want to
G
08-20-2007
#18 (permalink)
Great! You left that part out.
Actually, What I suspect I'll do is to buy the muffler kit (using the discount they offer when buying the bike), and break it in with the stock exhaust in place. Quietly puttering around for the first few weeks may change my mind (and enthusiasm) about rolling around on the 107 degree garage floor.
'07 Bonnie T-100 :D
08-20-2007
#19 (permalink)
hmm, I would look into it, as it may be different now, but when I got mine the offer was 500 bucks worth of stuff, and if you got mechanical parts installation was free. It wouldnt hurt it any to break in with tors on
G
08-20-2007
#20 (permalink)
Thanks. I'll check it out.
'07 Bonnie T-100 :D
