» Links |
08-14-2007
Valve clearance?
Haynes manual says every 12,000 miles or 2 years, called the dealer and they said it won't need it for another 5000 miles ( 7200 on bike, 2 years old in 2 days). Now the bike goes to the dealer tommorrow for an oil leak form a bolt behind the starter. Should it be done now or wait another 6 months when I get to 12,000 miles, Thanks
My dealer, whom I trust, told me not to worry about it until 12,000 miles.
Marty
08-14-2007
Moto Grand Prix Favorite Bike: '05 Bonnie Black
Posts: 3,087 Other Motorcycle: '06 Vulcan 500 LTd ~Sue's
Here's the thing. The Haynes says 12K. The Owner's Manual says 8K. I never looked at the chart in the Owner's Manual so I missed the 8K and did it at 11K. Nothing out of spec. I reckon I'll wait to at least 20K before I do it again. OR when the engine gets quiet. That is never a good sign.
My indy mech tells me, and he is good, that if shim in bucket valve systems don't go out of spec in 12K they are unlikely to go south for a long, long time. Hope he is right.
Monte
Monte
"The Old Ohio Preacher Man"
08-14-2007
valves
buds BA has had an exhaust valve click on the left side for 6+ mo0s. He isnt too worried about it so ? Got 11000 mi. I agree that if they dontgoout by 12000 mi then you gotsome time till they do. I remember the old Jag days. I think (same shim) valve adjustment was like30-40000 mi?? I only remember doing it once tho & it was an old car. When that time comes it will nbe time to tweak the engine!! Till then ride her & enjoy!!
CAPT D
08-14-2007
SuperSport Favorite Bike: my next one
Monte
Monte, I believe that Triumph has once agian backed off on the service schedule for the valves. I'm pretty sure it is 12k now.
Notice I hedged in that I said "pretty sure". (almost positive)
I had an oil leak at the cam cover at just about 8K miles. since the cover was off then I checked the clearences. 2 were slightly tight.
08-14-2007
CHECKING the clearance is pretty cheap...if you trust your mechanic to be honest about the results - ie don't tell you you need adjust when you don't.
So have him check it, what the heck.
08-14-2007
SuperStock Favorite Bike: '06 T100
Or even cheaper and easier yet.... get a feeler gauge and check them yourself. Checking them is easy. Changing them takes a little more time and patience.
Chances are they'll be ok.
Some people are a lot like Slinkys.
Not really good for anything, but bring a smile to your face when you push them down the stairs.
08-14-2007
World SuperBike Favorite Bike: '03 T-100 & '07Tiger1050
Yeah, Triumph changed the 8K to 12K for the valves.
Time factor: I can see the reasoning behind a time factor for oil changes; however, I fail to see the reasoning behind a time factor for valve clearance adjustment.
Larry
Larry
08-15-2007
SuperSport Favorite Bike: 2001 Bonneville (cafe)
Posts: 1,195 Other Motorcycle: 2003 Honda XR650L Extra Motorcycle: 2008 Suzuki V-Strom 650
+1 with what others are saying. Just wait till 12,000 miles. And checking the valves is easy -- don't be afraid to do it yourself. I checked mine at a little over 12k and didn't have to adjust any, although two of the exhaust valves were a little on the tight side. I just checked the valves again at a little over 18k to make sure those exhaust valves hadn't tightened up more; no change there, but two of the intake valves loosened up ever so slightly. Once again, not enough to bother adjusting them.
At 24k I'll check them again, and at that time will probably adjust them to get all valves right in the middle of their spec range.
--mark
Bennington Triumph Bash
Bennington, VT May 30-June 1, 2008
Thanks to all who attended!
Do you keep one bullet left for yourself, for when it's all over and done?
08-15-2007
Team Owner Favorite Bike: 2003 T100
Posts: 3,782 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: No more at present time
Interesting tidbit about valve adjustment on new BMW F800
Apparently, the recommended mileage for this bike is 12K. However, the tech plugs in the 'computer' that checks several items, mostly electronic. One item it checks is mileage compared to how hard the engine has been run .... the bike computer probably logs how many times or how long the bike is run at high rpm. If ridden easily, it'll recommend a longer valve adjustment interval, if ridden hard, a shorter interval.
Not sure I like this!
Bob
