Adding brake fluid....first timer question - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 08-12-2007, 02:49 PM Thread Starter
Question Adding brake fluid....first timer question
noticed my rear brakes seemed really "squishy", so I checked the rear fluid level and it is right on the "Lower" line, maybe a tad below. So I'm going to add some fluid, but was wondering if and DOT4 fluid is ok or if I need to stick to EXACTLY what was used before? Also, do I need to bleed the brakes after adding fluid? Thanks.
Tenover is offline
post #2 of 6 (permalink) Old 08-12-2007, 03:08 PM
Stealth's Avatar
Dot 4 is fine and you don't need to bleed the brakes. By the way 4 of us here in Florida checked ours and they were all on the low mark or a hair above it. maybe that's how they save money at the Hinckley Plant. Who knows?
By the way, Vavoline makes a super performance brake fluid that can be used in Dot 3 or 4 or 5. Discount Auto sells it.
Stealth
Put your arms and legs inside the ride at all times!
Stealth
125 main /42 pilot /Predators /K&N air/Mobil1 oil Triumph oil filter
Stealth is offline
post #3 of 6 (permalink) Old 08-12-2007, 03:15 PM
Main Motorcycle: Bonneville T100 2007
Suppards's Avatar
DOT 4 fluid will be fine - chances are that's what's in there already. It may be worth you checking the wear on the brake pads because as they wear out the fluid level drops.
Provided the pads are okay, you can just top up the fluid. If the brakes feel fine after this there's no need to do more.
If they still feel "squishy" after you ought to bleed them as there could be air present in the system which will reduce braking efficiency markedly. Brake bleeding is pretty easy to do and takes 10 minutes tops. If you've got a buddy who's done it before he/she can show you how it's done.
Suppards is offline
post #4 of 6 (permalink) Old 08-12-2007, 05:54 PM
greyplague's Avatar
I agree with the above. TIP: use a rag to protect paintwork 'round the reservoir while topping up.
Or don't and find out why you should have...:
Whatever doesn't kills me makes me older.
greyplague is offline
post #5 of 6 (permalink) Old 08-12-2007, 07:12 PM
Main Motorcycle: 2015 Bonnie Newchurch.
amanger's Avatar
Other Motorcycle: Aprilia SR Max 300
pads
If your brakes are squishy and you have to add brake fluid you may find that the pads have worn beyond the service limit.If this is the case, replace the pads first as you will only have to take fluid out when you replace them and push the piston back in.Check the pad wear indicators,which are grooves in the pads,if they are not worn beyond the grooves then add fluid and bleed.
2015 Bonnie Newchurch, Staintunes, 20507 tune, J.B.S. Thruxton length shocks, Renthal low bars.
amanger is offline
post #6 of 6 (permalink) Old 08-12-2007, 08:52 PM
Other Motorcycle: 66 Bonnie Chop
Thinking the same thing. Most of us seem to wear our the rear pads at 7K or possibly sooner. Get some EBC pads as replacement, they last twice as long as the OEM pads.
Al
ssjones is offline
Brake fluid ? Mp350 Twins Talk 6 08-04-2007 06:53 PM
would a billet brake reservoir effect the brake fluid??? 24gt Speed Triple Forum 2 03-02-2007 08:11 PM
Brake fluid? Mesoam Speed Triple Forum 12 01-12-2007 02:31 PM
dumb question about brake fluid CafeBonne Twins Talk 6 06-15-2006 01:53 PM
Brake Fluid Fridgehq Maintenance & Workshop Talk 5 03-10-2004 09:53 PM
