There is a real "rat's nest" of wiring in the headlight shell. I would recommend pulling off the headlight reflector part and inspecting the wiring in the headlight shell...its possible that you will find a loose connection and some connectors needing to be repositioned a little to make more room for the headlight reflector and headlight bulb connection.
When someone says brake light, I almost always assume they are talking about the tail-light part of the tail-light/brake-light combo unless they specifically mention things only applying to the brake side of the circuit.
While you are in the headlight shell, it would be a good time to put some more dielectric grease on any of the connectors that look to be in need of some more.
Larry
