Ok, i couldn't keep quiet on this subject. I can think of several reasons it doesn't seem to be a PS job. The quality is so bad that i can't be 100% sure on all the points even when zoomed in because it's pixelated and blocky to a very bad degree when zoomed. But heres what i noticed.
1)-Cooling fins are there on the head which i would think are a no brainer......people who like this type of bike don't want a non traditional look. Witness the said faux carbs that are supposedly going to be on the mid to late '08 900 cruisers. But now look at the cylinders. I don't see fins there. thats would speak to the bike being water cooled and not a america engine photoshopped into a rocket.
2)-i looked at pics of my bike at the same angle as the 1500 pic and the cheese graters and carbs are WAYYYY out in plain view. On the 1500 pic you cant see any carb, real or faux, and nthe cheese grater is way inwards by comparison. this would seem to imply the engine is much wider than the 900. Or even if not, why no carb/faux carb in plain veiw.
3)-looks like shaft on the right side. On the rocket the disc is on that side
4)-why would the photoshopper bother changing the headlights? If it's a rocket front end anyways, changing the lights isn't going to make anyone NOT consider the fact it looks like the rockets front end.
5)-rear rocket fender isn't flat ended like the speedmaster\america.....it's pointed. The pics seems to show a flat eand
6)-rear tire looks smaller than the rocket
7)-lastly, the pic is from MCN's august edition cover and was found at a MCN site address. So it's not like someone photoshopped it and then uploaded it to his storage server as a joke. So it actually IS from the august MCN cover. Would they actually fake a pic like that? I would think not considering it would be legal suicide if triumph saw it.
That said, i still question it. But while i'm not crazy about the water and would worry about initial design bugs, i will likely be one of the first adopters when it arrives if it does indeed look like the pic, tho hopefully like the 900 cruisers there will be a black engine speedy-like version too. Anyways, those are just some thoughts i felt should be considered. talk amongst yourselves....i'm verklempt.
2005 Speedmaster, Neon Blue, Thunderbike pipes, snorkel removed, UNI filter, drilled airbox, 130 mains, TBS needles.(2 shims) And speaking of Speedmasters,
HERE'S MINE
