Old 07-31-2007   #1 (permalink)
Favorite Bike: 02 bonneville
bonniegirl's Avatar
tool kit
i'm looking to put together a basic tool kit for my 02 bonnie just in case i run into troubles out in the world. suggestions?
thanks!
bonniegirl-vel
bonniegirl is offline   Reply With Quote
Old 07-31-2007   #2 (permalink)
Question tool kit
A can of "fix a flat" or slime or? WhaTEVER is the most fitting. I use slime w/ pressure enuff t oget t o a station. Not a real fix Just temp . Will limp you to a shop. Beyomnd that a screwdriver w/ a philips/ slotted reversable bit, pliers & some duct type tape. A jumper wire can be handy as well. Not much you can do on the road these days cept keep on goin as best you can? Sm vice grips will be better than pliers?
CAPT D
Old 07-31-2007   #3 (permalink)
don't forget an allen wrench for the under seat bolts
Mattrat is offline   Reply With Quote
Old 07-31-2007   #4 (permalink)
A Swiss Army knife, an adjustable wrench and some zip ties.
jedrake73 is offline   Reply With Quote
Old 07-31-2007   #5 (permalink)
Antny's Avatar
I bought one from NB made by Cruz tools. had evrything you need. except duct tape and extra spark plugs. I think www.jcwhitney.com has the same one that I bought for cheaper.
Antny is offline   Reply With Quote
Old 07-31-2007   #6 (permalink)
bendavanza's Avatar
18mm spark plug wrench, extra plugs, zip ties, piece of wire, taillight bulb, multi tool.
-Ben
http://www.bendavanza.com
bendavanza is offline   Reply With Quote
Old 07-31-2007   #7 (permalink)
RonD's Avatar
Other Motorcycle: Triumph Hurricane
Extra Motorcycle: several bsa,s
first thing you need to do is talk to some one mechanical, and learn a few basic pointers on roadside maintenace tools are useless if you dont know what your doing just a suggestion..
Regards Ron
Hurricane pictured(Harry)
RonD is offline   Reply With Quote
Old 07-31-2007   #8 (permalink)
DannyChrist's Avatar
zip ties/Bungies
I carry zip ties & bungies, because I have noticed the the sidestand spring sometimes fails, & when that happens you aint goin nowhere.
An adjustable wrench is also good for the spokes, just had my 1st flat, the tire slime was useless, best thing I had was AAA RV/Motorcycle Plus, flatbed tow up to 100 miles
DannyChrist is offline   Reply With Quote
Old 07-31-2007   #9 (permalink)
What goes wrong on the road?
I'm thinking along the lines of RonD. Instead of "Which tools do I take?", I wonder "What can go wrong that can be fixed on the road?".
Since I haven't been disabled yet except for one flat tire, DannyChrist's information about tying up the sidestand is good. I'll have to find a place on the bike to stash some zip ties, maybe where the owner's manual used to live.
I always carry a small flashlight with me, because if you can't see it, you can't fix it. I'm quite sure that's an essential item.
I have the AMA MoTow service, but I'm not sure how effective it is.
Marty
Baltobonneville is online now   Reply With Quote
Old 07-31-2007   #10 (permalink)
Question kit
I forgot the tailight bulbs!! The FaF stuff is only good if it has enuff pressure in it t okeep goin. Also I have progressive ins & they cover the tow & the 1st hr labor for $8 /yr!! That should doit ?
CAPT D
tool kit modre Twins Technical Talk 0 02-04-2007 09:49 AM
Tool Kit zugspitz Twins Talk 6 06-18-2006 09:01 PM
tool kit narrowminded Trophy 13 11-28-2005 11:50 PM
Tool Kit Lobo Twins Talk 20 11-26-2005 11:17 PM
where is (was) my tool kit? Sprintster T3 Sport / Touring Forum 4 10-02-2004 06:13 AM
