It is possible for the crank case to build up enough pressure to oil up the filter as the crank case vents to the air filter box.Check the airfilter which behind the side cover.If the airbox is all oily then that maybe your problem.If you have to replace the filter,buy a unifilter or k&n so you can clean it and reuse it.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
