» Links |
07-30-2007
Newbie Favorite Bike: My Black And Pearl T100 of Course!
Posts: 1 Other Motorcycle: Shwinn Bicycle Extra Motorcycle: Huffy With Bannana seat
Removing AI
Can anyone tell me where exactly the AI is located so I can remove it from system. A pic of it would even be better. Thanks. P.S. Its on a bonneville T100
Shut Your Trapps!:beerchug:
its under your gas tank, except for a few hoses, and bolted with 2 fasteners to a tab on the underside of the backbone framerail
G
I just wanted to ride
07-30-2007
ai
There was a picture thread a while back. Find it on the WIKI site if you can figure how to get there? Easy as said under tank. Take it off & remove all the attached junk. Put in your plugs/ bolts & your done .Takes about 1 hr takin your time. Makes a real differemnce! While your at it - wire tie up all the hangin wires under there. Cleans things up real nice!
CAPT D
07-30-2007
Here's a link for AI removal ...
http://www.labradorretriever.se/airemoval/
He does it on the cheap. If I were doing it, I'd use an AI removal kit with all the bits, it's cheap enough anyway (around $25).
Marty
07-30-2007
I went w/ the BC AI removal,they come with instructions and well worth the 25.$ and what was crazy is that the ai reed valve mounting location and bolts were perfect for grounding nology cables! almost like it was ment to be..
07-30-2007
Get rid of that little trouble making A1.
Put your arms and legs inside the ride at all times!
Stealth
125 main /42 pilot /Predators /K&N air/Mobil1 oil & filter
07-30-2007
The AI valve mounting holes and screws are good for relocating or installing a new horn too. It's a perfect space as long as the horn is not too big.
Marty
07-31-2007
Powerbike Favorite Bike: '06 scrambler
Posts: 309 Other Motorcycle: 1980 Vespa P125X "superstock"
fill in the newbie
What's the injector there for? and why would one want to remove it?
I imagine not just to make it easier to access the plugs...
07-31-2007
Formula Extreme Favorite Bike: Triumph Bonneville (of course)
The air injector is there to help the bonneville pass emission standards. It helps burn up gas in the headers before it leaves the pipes. Take the stuff off...it's not needed it all
TOR's, AI removal, Polaris bellmouth, K&N air filter, 118 jets, Hagon progressive fork springs, Progressive 440 HD shocks, sissy bar, summer wind screen, union jack brake resevoir
07-31-2007
ai
Its like the cars of the 70's. They had an air pump that pumped air over the exhaust valves. A very PRIMITAVE form of pollution control! Get rid of it!~!
Does very little for polluton as if bikes poluted that much? Does much bad for your Bonne tho!
CAPT D
