» Links |
07-28-2007
carb sync w/ out tach?
how do you sync w/ out tach-- setting rpms any recs??
thanks tt..
Formula Extreme Favorite Bike: 07 America
My question also! Will be interested in the replys as I'm ready to sync them instead of the dealer.
07-29-2007
think i might need to install a mini tach 75-80 $ any one know the ratio for the speedo??
07-29-2007
I have a tach, but I don't really find it completely necessary when doing a carb synch. Just warm the bike up to normal operating temp and then turn the idle speed screw to keep slowing the idle until it sounds like it's going as slow as it possibly can without dying - so it sounds like a tractor (this will be about 500 rpm). Then see if the carbs are synched up. Once you get them adjusted, turn the scew in one more turn to raise the idle (should be about 1500 rpm at this point) and see if they are still synched up. Adjust and turn the scew another half turn and repeat. Reset your idle where you like it and you're done.
07-29-2007
Formula Extreme Favorite Bike: 1952 Vincent Black Shadow
Posts: 462 Other Motorcycle: 2002 Bonny Extra Motorcycle: 2002 Sprint ST
You don't use the tach, you use a vacuum gauge or manometer attached to the vacuum ports on the carbs. You can buy a couple of vacuum gauges for about $25 and some plastic tubing.Mount them on a piece of wood, and clamp the tubing to dampen down the pulses, then set idle around 2000RPM and adjust synch screw until both readings are the same. Reset idle, then connect the two vacuum ports with a piece of the tubing and you should stay in synch for ever, or until you adjust the valves.I can e-mail you a PM with pics if you want.
If you want a nice little tach thats easy to instal, get a harley minitach from pwersports outlet store for $50, item # 300022590792.
Stu
TORs, NARK, thruxton needles, 140mains.40 pilots 2.75 turns out, procom igniter, 17T
07-29-2007
I've read instructions for synching the carbs that call for upping the idle to 1200 rpm, synching, then bringing the idle back down to 1000. But I have always just done it with a fully warmed up bike at normal idle. Like stu said, you depend on a good manometer (either mercury carb sticks or something like the CarbTune, which I use), and the tach is quite secondary.
2005 T100
07-29-2007
Posts: 763 Other Motorcycle: Triumph Hurricane Extra Motorcycle: several bsa,s
the taco is not realy needed in carb synching as the guys have said ,the main thing is vacuum guages, and i usualy check adjust right through the rev range, all u need for that is your ears, if u know what your doing when tuning your bike your listening to your engine, reading your guages and doing proper plug chops ,i peronaly dont use oversized jets a full set of jet drills going up one size at a time (this method is not for everyone) ,when u know what your doing combined with all you have read on the posts here u can acheive a good result . and on the older bikes high rpm pilot settings can be usefull ect..
Regards Ron
Hurricane pictured(Harry)
07-29-2007
thanks for all the input- the question was derived from every thing i searched in the site as far as :example running it up to 1500 rpm-thanks jedrake for the tips -
07-29-2007
who is pwersports?
"harley minitach from pwersports outlet store' "
Who are they? I tried to Google them with no result, thabkjs.
07-29-2007
Ya do it by listening...
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| carb balance/sync |
sweatmachine |
Twins Technical Talk |
9 |
12-23-2006 01:34 AM |
| carb sync |
caspianthruxton |
20 |
11-22-2006 06:07 PM |
| Carb sync |
Hilts |
5 |
08-27-2006 07:48 PM |
| Carb Sync Help |
FunCrusherPlus |
Twins Talk |
13 |
07-25-2005 09:49 PM |
| Bouncy Tach Needle - Carb Sync??? |
jasmail |
Hinckley Classic Triples |
20 |
12-08-2004 09:31 PM |
