can i ask for some clarification on the "looseness" you guys are talking about?
i've got an 06 T100, and i notice that once i get above 30 or 35mph, i can give the handlebars a little shake and the bike wobbles a bit. not enough to change my direction, but enough to cause me concern. at higher speeds, the wobble is still there, but i honestly don't shake it enough to check it out fully, since i don't want to take a spill at 65mph.
the wobble feels like the frame and perhaps even the front forks are sliding back and forth horizontally, but the front tire remains planted. the only real worry i have is sometimes on the twisties, when leaning the bike back and forth, there's a slight delay between my intent to turn and the actual turn. it's not long enough to be dangerous, but i'm concerned that when i really need it (like swerving to avoid a deer or car), that delay will be trouble.
i checked tire pressure and we're good at 33psi on the front, and as near as i can tell the bearings are tight. the bike only has 1200 miles on it.
would a steering damper help this out? is there something else wrong with the bike?
thanks for the help!
nick
"Each day is a journey, and the journey itself home."
-- Matsuo Basho
06 Bonneville T100 (AI removed, snorkel IN, stock otherwise)
