Old 07-28-2007   #1 (permalink)
Angry indicator problem...
My front left indicator on my Speedie has stopped working. The rear left one still works but now blinks twice as fast. I've tried replacing the bulb but this makes no difference.
Had the bike serviced (first service/500 miles) two days ago and am reluctant to make the ride back to where I bought it. Any suggestions welcome!
thanks
jon
JonCG is offline   Reply With Quote
Old 07-28-2007   #2 (permalink)
Favorite Bike: 03 America
EnglishWombat's Avatar
Other Motorcycle: 06 America
Extra Motorcycle: 1945 Triumph 3HW
My 06 America does that too.
I wiggle the cable that goes to in around the plug connector and it makes the indicator work...
It's one of those annoying intimitant faults that if you went to the dealer with they'd find nothing wrong.
Gina
http://bestsmileys.com/animals/7.gif
EnglishWombat is offline   Reply With Quote
Old 07-28-2007   #3 (permalink)
Favorite Bike: My 07 TBA
midlifecrises's Avatar
Smile moulding
I had a similar problem with my 07 TBA. Turned out to be a bad moulding in either the plug or switching unit. They missed it the first time at the dealership because the problem was intermittent. Fixed the second time. No problems since.
midlifecrises
Age is no barrier.... born again biker!
07 TBA -- tacho, sissybar, footboards, windshield, AI removed, modified pipes.
midlifecrises is offline   Reply With Quote
Old 07-29-2007   #4 (permalink)
Smile
Thanks, wiggling the wire has cured it for now... I'll get the dealer to take a look when I'm next down that way
Old 08-01-2007   #5 (permalink)
Favorite Bike: 2003 Triumph Speedmaster (Red/Blk)
Pauley's Avatar
I had the same problem with the brake light while using the front lever. I took it to the dealer when it was still under warranty, they couldn't find anything wrong. It hasn't acted up since. I have a left turn signal rear indicator problem with my car too, but it's turning into a jalopy anyways.
Hey Benefits Lady, Can I retire now??
Pauley is offline   Reply With Quote
High-Beam Indicator Light Problem swish77 Twins Technical Talk 6 06-01-2008 09:40 PM
Turn Signal Indicator Relay Problem 02 Teknic Speed Triple Forum 2 10-09-2007 08:02 PM
Indicator help bgcntry72 Hinckley Classic Triples 1 08-16-2007 10:56 AM
LED indicator cross talk problem karter257 Club Cafe 6 07-08-2005 03:02 AM
Instrument assembly plug - temp indicator problem Jcatbert Modifications & Workshop Talk 5 04-25-2005 01:38 PM
