BikeBandit
Old 07-25-2007   #1 (permalink)
Favorite Bike: Was 2006 Black Bonneville
oldmanjob's Avatar
Torqueing engine pipes
What is the proper torque when replacing engine pipes? I was told hand tight would be fine. At my old age my hand tight is not the same, as my 6'8" 330 lb son
John 14:6 KJV
Black Bonnie - 06
Looking back to the good old days is not the way out. Looking up to the God of All the Days is. (Vance Havner)
oldmanjob is offline   Reply With Quote
Old 07-26-2007   #2 (permalink)
oldmanjob's Avatar
I can't believe that no one has an answer to this question
John 14:6 KJV
Black Bonnie - 06
Old 07-26-2007   #3 (permalink)
OzRover's Avatar
From Triumph service manual (in Nm):
header pipe to cylinder head nuts: 19
header pipe mounting bolts: 22
header balance pipe clamp: 22
silencer mounting (footrest) nut: 27
silencer clamp: 22
Hope this helps
'01 Bonneville
OzRover is offline   Reply With Quote
Old 07-26-2007   #4 (permalink)
oldmanjob's Avatar
Thanks OzRover
John 14:6 KJV
Black Bonnie - 06
torqueing cylinder nuts firedog Classic, Vintage & Veteran 4 01-14-2007 03:38 PM
Axle torqueing procedure RedABSrider Sprint Forum 5 06-24-2006 12:49 AM
Question about Engine oil / Engine Covers on a Bonnie..... Brk4moose Twins Talk 6 05-31-2006 09:48 PM
2005 Speed Triple Dyno #'s- stock, pipes, pipes&map RbtWbbr3044 Speed Triple Forum 90 03-22-2006 09:23 PM
For Power Commander and Jardine pipes only. No 3 pipes should read this. rktmn3 The Rocket Science Forum 7 07-11-2005 05:21 PM
