Hi,
I bought an adjustable steering damper on ebay and was looking into fitting it to my bonnie. I know there are kits already made sold through new bonneville and bellacorse, etc. but I got a good deal on this one and I'm looking for a fork clamp to secure the damper to the fork. It's a standard 41 mm fork, and I do not have the standard headlight ears, so I have direct access to the tubes. I looked on ebay and found some turn signal clamps but they do not look sturdy enough to do the job. Does anyone know of a parts source for 41mm fork clamps? Or do you think I could use the lower pinch bolt to attach a bracket? Thanks in advance
specs are as follows
Storz Adjustable Steering Damper with 165mm Travel Model #SD-165 with STEERING DAMPER BODY CLAMP #SDC-025
-Ben
