Old 07-25-2007   #1 (permalink)
mlc
mlc's Avatar
replacement ignition coil brands
I was all set to test and if need be replace my ignition coil this weekend after many klm of lousy running, but it actually finally gave up the ghost of all places on the road going past the mechanic ive been taking the bike to.
He has confirmed that its cactus and wants to replace it with a GSXR750 ignition coil and lead set, but it seemed odd enough that i wanted to run it past you good people first. Are these suitable for an 06 Boneville 790 ?
What other standard units are suitable for the Bonneville that may be also readily available.
Incidentally, the triumph genuine unit is an astounding AUS$370.
thanks in advance
andrew
mlc is online now   Reply With Quote
Old 07-25-2007   #2 (permalink)
Favorite Bike: 2003 Triumph T100
I installed a Nology Profire Twin Tower coil ($75 US) with NGK Plug Leads ($50 US) from New Bonneville.com. This replacement was strictly preemptive in nature, as I have heard that the standard units will fail in time. I'm no coil expert, but I do know that there are differerences in ohm resistance requirements, depending on the bike. This is why I do my shopping with Triumph specialists...they eliminate the guesswork for me. Anyhow, a thumbnail follows:
Old 07-25-2007   #3 (permalink)
mlc
mlc's Avatar
yeah sheepdog they seem like the ones to go for. Im trying to track them down here in Brisbane. im trying to come up with a polite way to talk the mechanic down from the suzuki kit he wants to install. thanks for the info.
Old 07-25-2007   #4 (permalink)
Favorite Bike: Definitely my 2007 Black
Hedge's Avatar
Thumbs up Nology
I bought the Nology Pro Fire Coil and the Nology Hot Wires along with 2 NKG Iridium plugs from British Customs. I didn't waste a penny there!
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 07-25-2007   #5 (permalink)
Favorite Bike: 2003 T100 green/gold
mistermellow001's Avatar
Wire-Coil Connection
I'm surprised at how ill-fitting the rubber boots are on the stock plug wires (coil end of the wires). The boots don't seal at all, and in fact collect water like little cups when I wash my bike. Very sloppy engineering. Has anyone found, in replacing their wires only, that the replacement wires fit better on the coil?
Guy
mistermellow001 is offline   Reply With Quote
Old 07-26-2007   #6 (permalink)
What kind of benefit did you see? Did the engine run any smoother?
2006 Bonneville Black, TORs, Hepco and Becker Junior 30s, Corbin Smuggler
JTKMX is offline   Reply With Quote
Old 07-26-2007   #7 (permalink)
Hedge's Avatar
Thumbs up Nology
I had the dealer put this on a soon as she was uncrated. I can only go by what the Triumph Guru said to me. He claims it was the smoothest idling Triumph he ever setup and he is now sold on Nology and British Customs Performance Package.
Old 07-26-2007   #8 (permalink)
mlc
mlc's Avatar
had the coil replaced with the suzuki unit today. existing unit showed no resistance at all with a multimeter. it ran well and pulled strongly for the first 15mins and still does, but still running as rough as guts.
tomorrow off to visit a mate with a bonnie thats running sweet to swap out parts until we find the problem(s) hopefully. Maybe the suzuki coil, maybe dirty carbs, maybe balancing (although did this recently), maybe some other ignition part....
seems to get a lot worse the warmer it gets.
strong petrol fumes coming from right side pipe after i stop......
Old 07-26-2007   #9 (permalink)
ttbonnie's Avatar
I am putting nology-sparker,wires and plugs all from BC on tomorrow-
around 150- us +/-
ill sell you the stockers for 200... lol just kidding, pick up the nology's you will be a lot happier better product and not as expensive?! strange, but thats OEM for you
tt..
Ai removed , ARK, 19T counter, TOR's, 140 main 42 pilots 2.5 turns out- and a cleaned up body
heres she is
http://www.triumphrat.net/memberalbu...php?photo=1448
ttbonnie is offline   Reply With Quote
Old 07-27-2007   #10 (permalink)
mlc
mlc's Avatar
the heartache continues
coil swapped, ignitor swapped, leads swapped, carbs pulled and cleaned, float height checked, jets cleaned, fuel lines cleaned and bike still runs poorly.
definite improvement with the new coil (bike virtually died before - but now runs much stronger so compression not an issue i dont think) but still rough as guts and sounds like sh1t through the whole throttle range which gets worse as it warms up.
trailered it back to the dealer this afternoon. enough to make you either find or lose religion very quickly. Still, hoping its a dealer thing rather than a bike thing - but even that is academic at this point in time.
Ignition coil order muchelneybandit Hinckley Classic Triples 3 02-13-2008 03:51 AM
thruxton ignition coil Topomoto Twins Talk 4 03-23-2006 12:23 PM
Installing an ignition coil Dan_K Hinckley Classic Triples 2 10-21-2005 10:19 AM
bad ignition coil Hinckley Classic Triples 4 02-15-2004 12:11 PM
Ignition coil - aftermarket replacement trumpy Modifications & Workshop Talk 1 04-07-2003 05:27 AM
