BikeBandit
Old 07-25-2007   #1 (permalink)
Favorite Bike: 2007 Bonneville Black
TommyTwin's Avatar
Rev limiter?
Is it possible to over-rev a bonne? What would happen if you do over-rev an 07?
I've got to get a tach on my Bonne Black....I have about 1500 miles on her (AI removed, Airbox removed, rejetted and TORs) It seems like the higher the revs the better in 1st, 2nd and 3rd gears. She just seems to run better and better the more miles I put on her.
Anyway...rev limits?
TommyTwin is offline   Reply With Quote
Old 07-25-2007   #2 (permalink)
Stealth's Avatar
They truly are one tough Grunt.
Put your arms and legs inside the ride at all times!
Stealth
125 main /42 pilot /Predators /K&N air/Mobil1 oil & filter
Stealth is offline   Reply With Quote
Old 07-25-2007   #3 (permalink)
Anything is possible,but I think Triumph hedged its bets with the "lower than it needs to be" limiter.I wouldn`t do it on every shift,but once in a while won`t hurt it at all.
rodburner is online now   Reply With Quote
Old 07-25-2007   #4 (permalink)
Favorite Bike: 2007 Bonnie Green
Other Motorcycle: 99 Kaw KLR650
The conventional wisdom (on this web site) suggests that stock rev limiter will prevent damage, cutting out the motor at about 7500 rpm. You can buy aftermarket limiters with a higher rev limit, and it seems the bonnie motors can tolerate spinning at 8000 rpm and above without damage. That said, I wouldn't worry about hitting the rev limit on occasion, but I still highly recommend getting a tach. I had a tach installed on my bike before it left the showroom, and it's so nice to be able to glance down and know your engine speed. It is especially helpful since the motor is so smooth and relatively quiet.
Jim
2007 Bonnie Green. 865 cc motor with AI, emissions cannisters and airbox gone. NARK, 138/40 jets, 3 turns, 1 shim, slides drilled to 3mm. TORS, K/Q seat, sissy bar, 19T, and Parabellum windsceen.
JimSouba is offline   Reply With Quote
Old 07-25-2007   #5 (permalink)
Favorite Bike: 2003 Triumph T100
There was a thread at some point in which someone calculated the maximum piston speed for the Bonneville and it worked out to something near 9000 rpms (I'm working off of memory here, so please don't quote me). Many have stated that 8200 is no sweat. I routinely hit the stock limiter as my bike really feels like it is just hitting it's sweet spot at 7300 (and things really start to happen fast over 6000). If the price were not so dear, I would already have purchased an aftermarket ignition module to raise my rev-limit threshold. I would not worry about hitting the stock limiter at all, as it is a conservative countermeasure to over-revving.
Old 07-25-2007   #6 (permalink)
Favorite Bike: Modified 2005 T100
Other Motorcycle: 1994 CB750
It does depend on how long you want the engine to last, of course hitting the limiter wont blow it up, but it will sure wear out quicker if it is done all the time.
BeastInBlack is offline   Reply With Quote
Old 07-25-2007   #7 (permalink)
cdk80gs's Avatar
Hi, running mine on the Dyno with what I believe to be a stock rev limiter, I say believe as the bike had one previous owner but he didn't mention fitting a higher rev limiter, anyway on the dyno mine has hit 8400RPM before the limiter cut in and on the road I can get well over 8,000 showing on the tach before the limiter cuts in, on the Dyno though power is starting to trail off at 8250 or thereabouts
Chris
http://www.triumphrat.net/image.php?type=sigpic&userid=15807&dateline=118501  4177'04 Bonnie Black, Mototwin exhausts, Dynojet needles, 120 mains, K&N filter, AI & snorkle removed,18T
cdk80gs is offline   Reply With Quote
Old 07-25-2007   #8 (permalink)
The tacho is the first accessory I added. Get yourself one of D9's lay-flat brackets and install it while you're doing the tacho, it greatly improves the appearance. (If he still has any.)
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 07-25-2007   #9 (permalink)
Talking
Don't worry about it. I hit the rev limiter almost every shift for 2,500 miles of roadracing and track days last year, and when I tore the engine down to return it to street trim, no wear or damage was noted. Truly a tough, well designed engine.
thrux351 is offline   Reply With Quote
Old 07-25-2007   #10 (permalink)
Smile
was that after 50,000 miles? :P
rev limiter koifarm Twins Technical Talk 6 12-17-2007 02:11 PM
Rev Limiter wenzel850 Twins Technical Talk 1 10-03-2006 01:31 PM
Rev limiter Copper Twins Talk 8 01-22-2006 10:31 PM
rev limiter Jeno Hinckley Classic Triples 1 11-06-2005 03:06 AM
