BikeBanditMotorcycle.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 07-25-2007   #1 (permalink)
Favorite Bike: MINE OF COURSE!
unitedrocker's Avatar
Other Motorcycle: 2005 KTM 450
Extra Motorcycle: Coletta 6'2" pintail
K&N Filters
OIL FILTERS - Noticed that New Bonneville has the KN-191 filter for the Bonnie. The K&N site itself has the KN-204 listed for the Thruxton. Anyone know the difference? It also duplicated the Bonnie application for later years. Is this due to the larger displacement of the 865 motor?
Never settle for the usual.
'05 865 Thrux-ton - Super-Duper Modified: painted inner tube caps yellow, purple tassels on the bars, and pink neon lighting.
unitedrocker is offline   Reply With Quote
Old 07-25-2007   #2 (permalink)
Stealth's Avatar
K&N also change the numbers on the new air filters. I don't know if there is a difference other then the number. Why not use a filter built in the USA.
Mobil 1, Pure-One, NAPA or others?
Put your arms and legs inside the ride at all times!
Stealth
125 main /42 pilot /Predators /K&N air/Mobil1 oil & filter
Stealth is offline   Reply With Quote
Old 07-25-2007   #3 (permalink)
k&n numbers have changed, but thats about it. the thrux and bonnie have the same air box, and the same filter
G
I just wanted to ride
Old 07-25-2007   #4 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
My guess is there is no difference. My 2007 Tiger takes the same oil filter as my 2003 T-100 bonnie. New Bonneville will sell you the correct oil filter--Brent is a rider and uses them also.
Larry
Larry
Old 07-25-2007   #5 (permalink)
HiVel's Avatar
Larry- In my 05-865cc I am running the NARK, D&D pipes , 42's. 155 mains, stock needles and 3 turns out on my pilot screws. I see you are 1 turn out. My bike runs great , idles good and I am wondering if I have them too far out? I will hopefully get my Bonnie on the Dyno very soon to ck my A/F ratios. Most everybody seems to be running them 2 1/2 turns out at least.
Whats up? Thanks R
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 07-25-2007   #6 (permalink)
HiVel's Avatar
The oil filters I like are the Purolator Pure One and the Mobil One and the SS Scott reusable. We have the T100 and the Speedtriple and the '06 Sprint
in my garage and all three filters fit all the bikes.
Old 07-25-2007   #7 (permalink)
Favorite Bike: Bonnie black, Orange RS
haggis95's Avatar
WIX make good filters too
They are now available in Canada.
Now that's a pie!
haggis95 is offline   Reply With Quote
Old 07-26-2007   #8 (permalink)
Okay, I'm game, but what are the code numbers for these?
Old 07-26-2007   #9 (permalink)
Favorite Bike: '71 Norton Commando
CommandoRdster's Avatar
Other Motorcycle: '07 Scrambler
Extra Motorcycle: '71 BSA Victor B50MX
A lot of racer types like the little nut on the K&N,because it makes it easy to safety-wire. Personally,I wouldn't waste my money. Cut one open,and it's just an average filter. Not as good as the Wix,or Purolator filters. NAPA,and CARQUEST filters are made by Wix.
Here are a few numbers that might be useful.
Wix....51358
Baldwin...B1400
Fram.....Ph6017a
Hastings.....LF113
A/C......PF2135
Purolator.....ML16817
CARQUEST......85358
(I'm not sure if that is the PureOne,or the standard Purolator filter.)
I would use the Fram as a last resort only.The rest of these are excellent filters.
Hope this helps.
Cheers!
Bruce
ANIMAL RESCUE SITE-Please go there and click on the purple button!
CommandoRdster is offline   Reply With Quote
Old 07-26-2007   #10 (permalink)
HiVel,
You're trying to compare apples to oranges (865's to 790's)...the cam timing is that much different, IMHO. The jetting will vary greatly (between the 865's and 790's) for the bottom end and the top end. The 790's with NARC and open silencers really should be running size 40 pilot jets (stock), IMHO. I had the 42's in when it was set up on the EGA, so I left them in.
Another variable that affected the size pilot jets on my 790 is the headers. When I was running the headers without the crossover, I ran 45 pilot jets. As soon as I put the stock headers back on, I had to go down in size on the pilot jets. I liked the headers without the crossover from a performance stand-point (low and medium range torque was great). The reason I changed back to the stock headers was a product quality issue and a clearance issue.
Larry
Pod filters: K&N vs. Uni vs. ??? jcline8 Twins Technical Talk 7 01-05-2008 06:42 AM
K&N Filters tspapa Twins Technical Talk 2 09-22-2007 11:18 AM
K&N Filters NYTBird The Rocket Science Forum 13 11-27-2006 02:25 PM
K&N filters Rocketime The Rocket Science Forum 5 10-28-2005 06:40 PM
K&N Filters WildeKurt Tiger Chat 1 08-14-2004 04:07 PM
