Trident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
BikeBandit
Old 07-24-2007   #1 (permalink)
AI gone. What about ..
I removed the AI today using the AI removal kit that came with my D&D pipes. It was pretty easy and the bike looks cleaner now.
I was wondering, what to do with the hose on the right intake manifold shown in the photo below?
You take the left one off because it is attached to the reed valve. What about the right one?
2006 Bonnie Black - NARK, D&D pipes, 145 mains, 40 pilots, 3 turns out, AI gone, California Beans and Sprouts Package gone, rear pegs gone, Norman Hyde Single Seat, Carrand Horn
Donkeypunch is offline   Reply With Quote
Old 07-24-2007   #2 (permalink)
MES
Favorite Bike: my next one
MES's Avatar
Take and cap the right one also.
go to the auto part store and get a pack of 7/32" (3/16" will also work in a pinch but are very tight) vacuum plugs. They will come in sets of 6 (you only need 4) and cost a whole $2.00.
Get an extra pack because they start to crack after about 6 months. If you loose one on a ride the bike will run crappy at best and you will ruin your ride.
MES is offline   Reply With Quote
Old 07-24-2007   #3 (permalink)
Favorite Bike: '05 T100 Black & White
MotoSayle's Avatar
Other Motorcycle: '08 FLHTP
Cool
I bought the genuine Triumph caps.They match the others,aren't very expensive and are high quality.
....Confidence in the face of risk ! ....
MotoSayle is offline   Reply With Quote
Old 07-25-2007   #4 (permalink)
I bought the Triumph caps too, after the auto store caps rotted in three months. The Triumph caps will need to be replaced probably every year. Suggest you put the caps on with one of those little spring clamps for hose.
2005 T100
Old 07-25-2007   #5 (permalink)
I removed the hose on the right manifold as well. After the stories of breaking vacuum caps I decided to just cut some of the original hose and plug each end with a screw. I capped the other side that way as well. Knowing me I would never check the crappy rubber vacuum caps in time to avert disaster. I need something a little sturdier.
Now the question remains what to do with the other end of the hose that was running to the right manifold. I currently have it capped off. I noticed that it is running to this cylinder just in front of the rear wheel (see photo.)
What does that cylinder do and can it be removed? If it can be removed it would be good to know for those who are doing ARK's. If that cylinder is on the bike there is no way to drop the rear wheel enough to get the factory airbox out. Replies appreciated.
DP
Old 07-25-2007   #6 (permalink)
Wink can
Must be a Cali bike. Thats your evap emission canister. Mine didnt have it , but othere havetaken them off w/ no rpoblems. I assume you wire tied up all those wires hangin down? I did makesitr look muck cleaner! You will get some instructions how t oDX the can from some one I am sure. I didnt do it so Iwouldnt be able to help you much. I gotta get some more rubber caps- mine are leakin a little till warmup. Boomers commin on strong- gotta get off this thing!
CAPT D
Old 07-25-2007   #7 (permalink)
Hrrm. Wonder if GaryD wants to repost his "Removing the Evaporative Loss System" guide. I can't seem to find it anywhere.
Old 07-25-2007   #8 (permalink)
What about this set of hoses?
There is another set of hoses on each carb. They are linked together in the middle by a T connector and the resulting combined hose then goes back to the cannister.
I read somewhere that you are not supposed to plug the vents that drain the float bowl. Are these the float bowl vent tubes?
There is one other tube that connects to the carb setup. It connects to a bar that joins the 2 carbs. It then connects to a T connector. One side of the T connector goes to the underside of the gas tank and the other goes to the cannister. Maybe that drains the float bowls?
Does anyone have a copy of GaryD's instructions?
Thanks,
DP
