Old 07-23-2007   #1 (permalink)
vinchuca's Avatar
Angry Scary
At only 200 miles on the odometer I lost the "peg" of my gear shifter in the middle of the street!!
Not to be able to find the shifter at 35 mph in the middle of traffic can give you a scare. Thanks God I was not on the highway.
If any of you just bought a Bonnie, check her before you ride of the dealer.
The F#$@ing thing simply unscrewed itself lose until it fell off.
Found it (lucky me), added loctite and drove on.
JPV
vinchuca is offline   Reply With Quote
Old 07-23-2007   #2 (permalink)
Favorite Bike: Definitely my 2007 Black
Hedge's Avatar
I guess you could have hit the red Start/Kill switch on the right side and glided to the side of the road. However, that is easy to say from behind a keyboard when you have plenty of time to think -I bet in a panic situation that might not come to mind!
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 07-23-2007   #3 (permalink)
Favorite Bike: 03 Bonneville America
Gregger's Avatar
Other Motorcycle: 69 BSA 650
Scary isn't the word. Glad nothing bad happened other than loosing a few minute on the end of the old life. Got to go check mine now! Thanks for the update.
Can't wipe this smile off my face!!!!
Gregger is offline   Reply With Quote
Old 07-23-2007   #4 (permalink)
shifter
Good thing you found it- there not cheap!! What gear were youin when it dissapeared? Bummer I dont know how id feel if I went to kick her down a gear & nothing was there!!
CAPT D
Old 07-23-2007   #5 (permalink)
cdk80gs's Avatar
It shouldn't happen on such a new bike, the guys who did the PDI should have checked all nuts n bolts are tight, Ive had this happen in the past though on much older bikes, on an old A10 I had about 20 years ago the whole gear lever fell off, only found out when I went to change down from 4th, luckily back then I carried all sorts of tools and so attached a set of mole grips to the shaft and made my way home, no real drama just a little annoying.
Chris
http://www.triumphrat.net/image.php?type=sigpic&userid=15807&dateline=118501  4177'04 Bonnie Black, Mototwin exhausts, Dynojet needles, 120 mains, K&N filter, AI & snorkle removed,18T
cdk80gs is offline   Reply With Quote
Old 07-23-2007   #6 (permalink)
Thumbs down lever
Goes to show you what a bargain DEALER PREP really is!! I prepped my own bike when i gotit home. They left the axle nuts loose & the chAIN ready t ofall off! The intake rubber clamps were loose as a goose!! Most I have seen were the same way. If your gonna ride it - check it GOOD!!!
CAPT D
Old 07-23-2007   #7 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
I recently pulled and replaced the tranny on my old R100GS Beemer. And I recall spending lots of time aligning the shift lever, but apparently I didn't fully tighten the screw that held it to the pivot (unlike the Bonnie, there's a couple of rods and levers that make up the shifter). Weird feeling when you downshift from third to second (or try to) and there's nothing there!
Luckily, though they were dangling, all the pieces and parts stayed with the bike, and luckily the BMW toolkit contained the wrench and allen to put it back together, because I was in the middle of nowhere.
You can bet I double checked all the bolts I'd worked on when I got home.
Bob
Old 07-24-2007   #8 (permalink)
MES
Favorite Bike: my next one
MES's Avatar
I "lost a peg" last Saturday.
Hears the story.
The bike hasn't been running right. It's been making some noise coming out of 1st gear. I checked the clutch lever free play. It's OK. I check the chain tention. It's OK. so I deside to take it to the shop on Saturday and let them have a look see. They all take it for a spin and deside everything is OK. I'm not convinced, but my hearing isn't that good anymore so I deside to give the problem some more time and head on off for home.
I'm on the 405 freeway (the 2nd most used freway in the world next to the 10 which is 2 miles ahead). Traffic was very heavy but I'm making it ok. My exit is coming up, the traffic alway backs up right there, so I start to split lanes.
I get over into the exit lane and traffic opens up. I get on the gas and up to about 65. This is the same exit I always take. Day in day out. I know it by heart. A nice left sweeper into a 1/4 mile straight into a little righ. I'm being good. I'm only doing 70. I slow down slightly because I know at the very end of the exit there is a compression zone followed directly by a pronounced bump. I'm all set up for it. I got by butt off the seat slightly to help the suspention. I hit the compression zone with my full weight on the pegs. I hit the compression zone and my left foot pegs SNAPS. My foot hits the ground and kicks back up. I'm slightly off balance just in time for the bump. Next thing I know the front end is all over the place. I ain't talking no Janet Reno parsensons head shake, It was the full seizure.
I can hear the cars behind me get on the brakes. I keep my speed up and very slowly ease up on the throttle. I ride it out and have put some distance between the cars behind me. I had just enough time to check my mirrors and take the turn at the side street at about 45. I come to a stop and shake it off.Now I have to go back to the the exit and dodge traffic after I find the peg. I find the peg. right in the middle of the freeway exit. I wait and pick my time and grab it. I'm only 4 blocks from a bike shop so I just get into 2nd and rest my left foot on the back peg. No big deal, just looks kind of strange. I explain what happened and borrowed the tools to swap out the back peg for the non existent front. I call up the boys at
S. B. T. and tell them what happened. sure enough they got the part that I need laying around.
So, back on the freeway for a 15 mile lane spitting skills test. get to the shop and swap out pegs agian. Back on the freeway for another round of lane splitting and off at the same exit where I snapped the peg.
The good news is I remained upright ( it wasn't really that close but it was close enough). I got the part I needed and there was lots of cold beer waiting for me when I got home. My after market shocks and front spings should be ready any day now. Thank GOD.
(maybe I should consider a fork brace and steering dampner in the near future. I'm not really keen on them but after that I can see their appeal.)
The bad news is I'm still not convinced that the bike is rite. My hearing is pretty bad, but I swear That clutch ain't rite. And I'm probably not going to Cambria.
MES is offline   Reply With Quote
Old 07-24-2007   #9 (permalink)
MES, what was the cause of the peg coming off?
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 07-24-2007   #10 (permalink)
MES
MES's Avatar
I had all my weight (and there is a fair amount of it) on the pegs. The bike compressed and SNAP.
I do that exit almost everyday and repeated jarring probably caused metal fatigue.
It wasn't the actual peg that broke. It was the peg mount that attaches to the the frame.
It looks a little SCARY Pic's bonnevillebilly Twins Technical Talk 36 12-28-2007 09:38 PM
Wheelies scary **** Psydone Speed Triple Forum 12 09-10-2006 05:45 AM
scary temperatures rino2301 Daytona Deliberations 33 09-08-2006 07:21 PM
A scary moment dazco Twins Talk 0 08-06-2005 04:13 PM
RS brakes---scary! Sprint Forum 8 04-07-2005 07:59 PM
