Old 07-19-2007   #1 (permalink)
can:t find idol mixture screws
Hello,I ve got about 1300 miles on my 2007 bonnie black ,great bike.the problem is Ive got some popping out the mufflers after pulling baffles out, I think I need to richen up idle mixture screws.can some one post a picture where there at .Thanks
johnz is offline   Reply With Quote
Old 07-19-2007   #2 (permalink)
Stealth's Avatar
Remove the A1 air injection system.
Put your arms and legs inside the ride at all times!
Stealth
125 main /42 pilot /Predators /K&N air/Mobil1 oil & filter
Stealth is offline   Reply With Quote
Old 07-19-2007   #3 (permalink)
Exclamation Ditto
On removing the A/I. The screws are under the carbs in front of the heaters. They are a D screw. I opened mine 1/2 turn as recommended here & it smoothed things out nicely. DX THE A/I 1st!!
CAPT D
Old 07-19-2007   #4 (permalink)
Favorite Bike: Norton F1 Sport
DuckMan001's Avatar
Other Motorcycle: 06 Thruxton
Extra Motorcycle: 95 Trophy 1200
Loosing the AI will help a lot
Never ask a man if he's from Texas. If he is he will tell you. If he isn't there's no need to embarrass him.
DuckMan001 is offline   Reply With Quote
Old 07-19-2007   #5 (permalink)
Here's a link to a bottom view picture of a Keihin CVK40 carb. Click on the link, the pic is bigger than the attachment view.
http://www.gadgetjq.com/keihin_carb.jpg
BillT100 is offline   Reply With Quote
Old 07-19-2007   #6 (permalink)
Stealth's Avatar
by the way where do you get those D screw drivers?
Stealth
Old 07-20-2007   #7 (permalink)
D-screw adjuster tool: http://www.newbonneville.com/html/d_tool.html
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes, Unifilter, no snorkel, 120/40/Thrux needle/1 shim/3 turns, fly screen, tacho, D9 gauge panel, center stand, Ikon 7610s, Hagon fork springs, gaiters, Pirelli Sport Demons, 3 seats.
Old 07-20-2007   #8 (permalink)
DuckMan001's Avatar
I got the OEM tool from my dealer... 19 bucks
A/F mixture screws tspapa Twins Technical Talk 4 11-06-2007 04:06 AM
mixture screws... lucky23 Twins Technical Talk 6 08-09-2007 02:23 PM
Mixture screws? webonnielad Twins Technical Talk 3 05-08-2007 01:57 AM
Mixture screws CAPTDON Twins Talk 3 08-07-2005 07:17 PM
mixture screws robbie Hinckley Classic Triples 3 04-06-2005 09:00 AM
