Old 07-18-2007   #1 (permalink)
Favorite Bike: 05' T-100 Blk & Wht
nwraindevel's Avatar
2005 t100 It looks like I have an Oil leak!
Has anyone else had any leaks on a 2005 bonneville t100? Please let me know what the problem was, if possible. thanks
nwraindevel is offline   Reply With Quote
Old 07-18-2007   #2 (permalink)
Kinda
Just a wee bit of seepage from the oil galley bolts behind the starter. At this time it's not serious enough to warrant fixing. Everything else is bone dry.
MacStuf
The dogs may bark but the caravan moves on
2005 Triumph Bonneville T100 (current)
2001 Ducati 900SSie (gone)
2004 Suzuki GSXR600 (gone)
1984 Honda Nighthawk 700S (gone)
macstuf is offline   Reply With Quote
Old 07-18-2007   #3 (permalink)
Sounds The Same
That sounds like the exact same place my leak is coming from. Last weekend I rode a 600 mile trek and my oil level did not seem to be down at all. But when I park I see little drops of what looks like oil right under the starter.
Old 07-18-2007   #4 (permalink)
mecscc's Avatar
You guys have to cut this out! I've been trying to calm newbies by telling that the Hinckley puppies don't dribble like the old puppies used to do!
Monte
"That ain't a leak, Son, its persperation!"
Monte
"The Old Ohio Preacher Man"
Old 07-18-2007   #5 (permalink)
My 04 Thrux started leaking around the bottom of the clutch cover at 4k miles - but - it had been sitting outside and not ridden in a year when I bought it. New gasket solved the problem.
Bonafide is offline   Reply With Quote
Old 07-18-2007   #6 (permalink)
Yep
You can find several other Bonneville owners on the forum here who have the same leak. Some have been able to correct it themselves, others have taken it to their dealer to fix. I'm not extremely well versed on this particular leak problem but it doesn't seem to be a big deal to fix. As I said earlier, my seepage is so slight that I just occasionally lay down beside the bike and wipe away the few drops of "moistness" that is there. My oil level does not seem to be affected at all. It's one of those things I'll get the dealer to fix this winter when he is less busy and I'm not riding as much.
Old 07-18-2007   #7 (permalink)
common problem
This seems to be a normal thing on the new bonnevilles. Slight seepage from oil sump. Hard to get to to fix so I have left it alone. Only leaks when running when pressure creates a small seepage. You can either live with it since it will never affect your oil level or if you are a perfectionist you can remove the bolt with an allen wrench and put some teflon tape around the threads and put it back in again. You have to dismantle a few things to get to it.
This problem comes up a lot on this board along with 2 other common problems.
1. Can't get gas cap off
2. Can't lock front forks
Scott
From Winston-Salem, North Carolina, USA
Think you can, Think you can't, either way you're right.
merlotlover is offline   Reply With Quote
Old 07-18-2007   #8 (permalink)
Maybe I missed something, but nwraindevel, where do you think you have a leak?
2005 T100
Old 07-18-2007   #9 (permalink)
Favorite Bike: 2003 T100 green/gold
mistermellow001's Avatar
I didn't have a leak until I replaced my clutch cover. Against my own advice, I dry-fitted the gasket instead of using a light coating of sealant. It's a veh-wee veh-wee slow leak, but it bugs the crap out of me. I just got a new gasket, but I've forgotten the name of the sealant a Triumph rebuilder recommended to me. Any preferences?
Guy
mistermellow001 is offline   Reply With Quote
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
2005 T100 TOLLANA Twins Technical Talk 2 02-12-2007 05:37 AM
Triumph Sprint ST 2005 fuel leak BikerBore Sprint Forum 9 03-02-2006 01:21 PM
Oil Leak head gasket? and looking at Dennis's T100 at dealer jwpT100 Twins Talk 3 11-17-2005 08:39 PM
Winshield for 2005 T100 Ale Twins Talk 2 08-07-2005 05:09 PM
