Old 07-19-2007   #31 (permalink)
Have you metered those fuses? Sometimes a visual inspection isn't enough. It may look OK but may be open.
Jimi_X is offline   Reply With Quote
Old 07-19-2007   #32 (permalink)
Favorite Bike: 05 TBA
ErwinM's Avatar
Other Motorcycle: 1997 GT mountian bike :)
check for loose/corroded connection at the starter
Erwin
ErwinM is offline   Reply With Quote
Old 07-19-2007   #33 (permalink)
yeah, my thought would either be ground or ignition switch..
'07 Silver Bonnie
Seattle, WA
tc_dick is offline   Reply With Quote
Old 07-19-2007   #34 (permalink)
Favorite Bike: 2001 Sky Blue Bonneville
Might be wrong but I'm sure there's a fuse under the seat next to the CDI unit.
Ian
Skyblue62 is offline   Reply With Quote
Old 07-20-2007   #35 (permalink)
Favorite Bike: 2002 Bonneville
jjswetnam's Avatar
It's FIXED!!!!!
So after all this... it was a bad connection under the fuse BOX. The fuses weren't blown, but one of the connections had just barely slipped out.
Also, the previous owner apparently put in a wrong size fuse... it didn't blow, but it got so hot that it caused the connection to go bad. I didn't even think about fuse sizes, because come to find out, there is supposed to be a fuse box cover ... but I don't have one on my bike!
Problem was fixed by the dealer for $80. After that, I spent the day with my girl... put another 100 miles on her and she started up like a dream every time.
I just wanted to say thanks to everyone for your responses and advice. It's cool to have you guys here.
J.
"Ride like everyone's trying to kill you!"
jjswetnam is offline   Reply With Quote
Old 07-20-2007   #36 (permalink)
Good to hear you're rolling again. Enjoy your ride.
Did you get a cover for your fuse box?
Old 07-20-2007   #37 (permalink)
jjswetnam's Avatar
No cover... yet. I'm gonna try and get one soon...
Old 07-21-2007   #38 (permalink)
webonnielad's Avatar
Alarm
Do you have an alarm on it.
My data tool system three gives me the same symptoms when it plays up.
It also has an engine immobilezer on it.
Jon (UK)
webonnielad is offline   Reply With Quote
Old 07-21-2007   #39 (permalink)
Thanks guys
You may all have just solved the same problem I have.
I'll let you know.
Jon (UK)
Electrical problem buzzbomb2002 Speed Triple Forum 9 02-19-2008 08:43 PM
Triumph sucks big time. Will buy Honda next time. drainbamage Speed Triple Forum 20 06-19-2007 11:39 PM
Electrical problem Pharmaboy Sprint Forum 6 04-02-2007 01:24 AM
new member..... big time S3 fan batistuta Speed Triple Forum 20 08-16-2006 09:14 AM
Airbox Leaking Big Time Hinckley Classic Triples 11 05-11-2004 05:51 PM
