mikeinva,
I started with 135 mains after installing the NARK and NH Togas because then I had Thrux needles in the carbs and had read (without thinking) that one needs smaller main jets with the richer needles. It ran no better than stock with the 135's. I immediately went home and put in 150 mains and it felt like it was lifting the front wheel in 1st, 2nd and 3rd gears at 6000 rpm. I went all the way up to 160 main jets without getting a "too rich" bog when suddenly opening the throttle at 5500 rpm. I had the dyno session already scheduled so the 158 mains were what the EGA showed best on the dyno. The dyno operator has been tuning race engines as well as stock and modified street bikes for many years...it took him less than 15 minutes to get the mains where he wanted em; however, we tried different needles for hours trying to get the mid-range closer to 13. I learned quite a bit that day, and it was very interesting to see the results of all the needle changes--NONE whatsoever on the size main jet needed. :-D
Larry
Larry
