Old 07-12-2007   #1 (permalink)
Favorite Bike: '06 Triumph Scrambler
Other Motorcycle: '96 Triumph Trophy
Extra Motorcycle: '72 Honda CB350F
After putting up with horrible gas mileage (consistently 29 mpg) and mediocre performance for a couple months, I decided to take drastic corrective action this weekend.
I removed both the AI system and the Evaporative Emissions Control system (temporarily, and for diagnostic purposes only, I assure you :-D ) and plugged up all the holes.
All of a sudden the bike sounded right, pulled the way it should, and best of all, after 300 miles and a couple fill ups, I'm getting over 39mpg. Instead of hitting reserve at 90-95 like before, I didn't have to switch over til 134 miles this last tank.
Thats with my riding like a fool, hitting the TON on the fwy a couple times, sustained cruising at 90, a run through Brea Canyon Blvd. I can't help it, she's running so good now she's just begging for it.
Still don't know exactly what the problem was, but it was somewhere in all those extra hoses and gadgets.
[ This message was edited by: JBarn3 on 2007-07-11 23:17 ]
--Josh
59 Club member #029466
'06 Scram. TORs, UNI filter, 120 mains, 1 shim. Ikon 7614 shocks, Progressive fork springs, EBC HH brakes, NB Scrambler SuperBars, PIAA Ion Crystal amber headlight, ...
JBarn3 is offline   Reply With Quote
Old 07-18-2007   #2 (permalink)
Favorite Bike: 2007 Bonnie Green
Other Motorcycle: 99 Kaw KLR650
Glad to hear you sorted out the problems on your bike! From what you've described, I'd guess that in removing the AI and evap systems, you probably fixed a minor vaccuum leak that was causing all your problems. Personally, I wouldn't replace either of those systems, and just keep enjoying the good running ride!
Jim
2007 Bonnie Green. 865 cc motor with AI, emissions cannisters and airbox gone. NARK, 138/40 jets, 3 turns, 1 shim, slides drilled to 3mm. TORS, K/Q seat, sissy bar, 19T, and Parabellum windsceen.
JimSouba is offline   Reply With Quote
Old 07-18-2007   #3 (permalink)
Sounds ready to run Turnbull Canyon/Beverly now.
I wasn't getting more than 100 miles per tank for the first few tanks, and then she loosened up and has been getting closer to 120.
2006 Thruxton
monkeyboy is offline   Reply With Quote
Picked up Scrambler - Wow! tri650 Twins Technical Talk 14 04-05-2007 07:51 AM
Progressive springs fitted - wow, what a difference (pics) keef Twins Talk 8 09-26-2006 07:49 PM
"Well sorted" ironduke Classic, Vintage & Veteran 8 03-10-2006 01:11 PM
Wow! what a difference the tor's make dseely Twins Talk 6 12-07-2005 04:24 PM
carbs sorted Daytona Deliberations 0 06-15-2004 02:51 PM
