BikeBanditbritishcustomsMotorcycle.com Classifieds!AdvanstarMotorcycleShowsRacerPartsWholesaleShopTriumph.comSpringfield ArmoryAnnitori DistributingMotorcycle.com
Old 07-10-2007   #1 (permalink)
TrOjAnUK's Avatar
Just done the jets and Uni Filter but Im still getting poppin on over run.
The setup is::
Main jet 125
Pilot 42
Mixture screws 3 turns
Uni Filter
Snorkles removed
TOR short exhaust
Should I back out the mixture screws another turn?
Also during testing, I maxed the rev limiter in 2nd and 3rd gear and the bike cut out, pulled over and restarted and its OK again.. any ideas on that??
TrOjAn
TrOjAnUK is offline   Reply With Quote
Old 07-10-2007   #2 (permalink)
Favorite Bike: 05 speedmaster - black
you might have to bump up the main jets.
I am running 130's with my UNI and scepter pipes.
but back the screws out first and see what happens, it is easy enough and costs nothing.
mag10 is offline   Reply With Quote
Old 07-10-2007   #3 (permalink)
Favorite Bike: 05 TBA
ErwinM's Avatar
Other Motorcycle: 1997 GT mountian bike :)
As Mag said I would turn your mixture screws out 1/2 turn each for the popping issue and up the mains to 130
Erwin
ErwinM is offline   Reply With Quote
Old 07-10-2007   #4 (permalink)
TrOjAnUK's Avatar
Called Peter from Jenks Jets and he reckons up the pilots to .45, they are the ones causing the low revs poppin.
I only just upped the mains from 120 to 125.. top end its fine..
Peter also mentioned that not to turn the mixture screws out too much as they may fall out completly, apprently they aint that long
Anyway, new pilots on order.
Thanks, TrOjAn
Old 07-10-2007   #5 (permalink)
ErwinM's Avatar
Sounds good. Let us us know how you make out.
Erwin
Old 07-10-2007   #6 (permalink)
Favorite Bike: Triumph Thruxville :)
BorgCymru's Avatar
Other Motorcycle: Another Triumph
Extra Motorcycle: TR1 Chop/Bobber
Got a number for jenks jets ? How much do they charge for jets there
BorgCymru is offline   Reply With Quote
Old 07-10-2007   #7 (permalink)
HAve you blocked off the Secondary Air Injection???
Popping on deceleration is caused by that system.
Thats the hose and pipe right by the spark plugs.
Get a block off kit for the SAI and your popping will be gone
HOG= Harley OWNER group
RAT= RIDER Association of Triumph
Matt_the_Rat is offline   Reply With Quote
Old 07-11-2007   #8 (permalink)
TrOjAnUK's Avatar
Matt_the_Rat,
Thats the first thing I removed as it used to be poppin at any revs on closed throttle... Ill try the pilots first, then move on to others if that dont work.
BorgCymru,
Jenks Bolts Peter Jenks is a real Gent, very helpful and knows a lot about the Bonny engines.
TrOjAn
Old 07-11-2007   #9 (permalink)
I too have the 45 pilots, as I recall they came with the pipes.
anyway, no popping.
Old 03-14-2008   #10 (permalink)
Favorite Bike: 2005 Bonneville
tward74058's Avatar
Other Motorcycle: 1970 Triumph T100C
TOR short exhausts
TROJANUK,
You said you had TOR short exhausts. I am looking for some shorter TORs. But all I have seen look similar in length to stock. Where did you find your and how much shorter than stock are they? Thanks and good luck with the popping.
tward74058 is offline   Reply With Quote
I just re-jetted my T-100 montpablo Twins Technical Talk 3 01-07-2008 10:51 PM
re-jetted for emgos Geoff Twins Technical Talk 6 03-01-2007 08:59 AM
I re-jetted...some tips doctorjay Twins Technical Talk 22 08-08-2006 08:03 PM
Please help..whole lot-a-poppin jdesane Twins Talk 8 04-12-2006 02:16 AM
Re-jetted to 115 mains...she screams! Liontari Twins Talk 13 03-04-2006 10:53 PM
