BikeBanditbritishcustomsMotorcycle.com Classifieds!AdvanstarMotorcycleShowsRacerPartsWholesaleShopTriumph.comSpringfield ArmoryAnnitori DistributingMotorcycle.com
Old 07-10-2007   #1 (permalink)
I'm looking for a partner for my '07 T100 ( so I can get the bl**dy thing off the wife ! :wink: :razz:
I may have found the right bike, low miles, 2001, 100% standard spec, supposedly immaculate, which allows me to develop it, if I/we choose. Apart from the the smaller engine....any 'generic' issues / gremlins ( or positives) I should be looking out for. Cases have been polished, so no lacquer issues.....it'll go quick, so I need to be decisive. Any spec changes that will be a problem ?
cheers....
'07 T100 Orange & silver....His
'01 790 Sky-blue & silver....Her's
Tritonshed is offline   Reply With Quote
Old 07-10-2007   #2 (permalink)
Favorite Bike: 2001 Bonneville (cafe)
Other Motorcycle: 2003 Honda XR650L
Extra Motorcycle: 2008 Suzuki V-Strom 650
The 2001 is the same basic bike as the 2007. Only changes they made over the years (aside from bumping up the displacement) are cosmetic.
My 2001 has been fantastic. I got it in the fall of 2004 with a little over 3000 miles on it, and by fall of this year I'll have around 20,000 miles on it. I've had no problems with it -- and I definitely don't baby it.
Buy with confidence.
--mark
Bennington Triumph Bash
Bennington, VT May 29-31, 2009
Do you keep one bullet left for yourself, for when it's all over and done?
markbvt is offline   Reply With Quote
Old 07-10-2007   #3 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
There is only one problem I know of that affected most 2001's--there is a service bulletin to replace a part inside the left left engine cover to stop oil from passing through the vent/breather tube to the airbox. A simple/easy fix that may have already been (should have been done) by the servicing dealer.
The cam timing is different on the 790, and it responds to mods VERY well. Some (I for one) prefer the 790 over the 865. If the price is right, BUY! :-D
Larry
Larry
Old 07-10-2007   #4 (permalink)
webonnielad's Avatar
Larry
Hear Hear!
Jon (UK)
webonnielad is offline   Reply With Quote
Old 07-10-2007   #5 (permalink)
CCR
why is there a difference between the 790 and the 865?
CCR is offline   Reply With Quote
Old 07-10-2007   #6 (permalink)
REVOLT's Avatar
I'd take the 790 over the 865...The two local shops here suggest the 790 over the 865 if your planning on performance mods later down the road...The 790 responds better to the mods...or as they like to say..."We can usually squeeze a little more out of the 790 over the 865..."
Right price? Good Shape? 790...? I'd take it...
The Bonnie Situation...
REVOLT is offline   Reply With Quote
Old 07-10-2007   #7 (permalink)
Favorite Bike: 02 Bonneville
Other Motorcycle: 05 SV650S
Wasn't there also some talk of clutch chatter on some 01's?
Also, some 01's came with very lean jets, 105?
I believe both should be taken care of already if properly serviced...
02 Bonneville - Originally green/silver , now going black. Dual headlights/black fly screen. Emgo Shortys, rubber bellmouth, Uni, AI, 120/42, thrux needles, no shims. Thruxton seat and low bars. Ikon 7614 shocks, renntec rack. A Bonnie Cafetourer..
ivar is offline   Reply With Quote
Old 07-10-2007   #8 (permalink)
Favorite Bike: HD
SuperMan's Avatar
Other Motorcycle: Crocker
Extra Motorcycle: UJM
The clutch chatter issue. Remedied with a new clutch center.
[ This message was edited by: SuperMan on 2007-07-10 13:27 ]
Go ahead, make my day...
SuperMan is offline   Reply With Quote
Old 07-10-2007   #9 (permalink)
Odysseus's Avatar
Clutch chatter is a problem on some 2001 bikes, mainly those from the first half of the year. It's an irritating problem but doesn't cause any issues from the point of view of wear on the engine, safety or rideability.
There was a service bulletin issued to replace the clutch basket, but some bikes (including mine) have the problem but weren't covered. It seems that if the bulletin doesn't cover your bike, Triumph won't replace the part (at least that's my dealer's story). Someone on this forum (can't remember who - my apologies) suggested beefed up clutch springs are the remedy. I've just had some fitted, but haven't had a chance to ride it to find out if it really sorts it out.
Apart from that, there are no real problems. You'll find the West Country climate will give you plenty of practice at polishing out rust spots on the wheel rims, mirror stalks, and anything else chromed, and riding in the rain will eventually have the same effect on some of the plating on parts of the engine covers. But I've found mine to be virtually bullet proof. It even took a hit from a stolen van whose driver was trying to make a quick getaway through me, and it didn't suffering unduly.
Oddball: Man, I only ride 'em - I don't know what makes 'em work.
Odysseus is offline   Reply With Quote
Old 07-10-2007   #10 (permalink)
Cheers to all for the responses.
Stand by for "warts & all" (if there are any!?) pics on Thursday, by which time she should be in the 'stable'.
Any body want to buy a Norton ??...................
[ This message was edited by: Tritonshed on 2007-07-10 15:18 ]
2001 TT600 issues bkjones Triumph SuperSports 5 07-21-2007 10:31 PM
Any problems with 2001 Bonnie? mlgatl Twins Technical Talk 19 10-07-2006 11:50 AM
2001 Bonnie question RandyDTFR Twins Talk 5 12-05-2005 09:57 AM
2001 Bonnie Copper Twins Talk 2 12-02-2005 09:21 PM
2001 Thunderbird for sale? Issues with '01's? Nightwatchman Hinckley Classic Triples 3 06-15-2005 05:25 PM
