The best way I know of is to put the bike on a dyno with an Exhaust Gas Analyzer (EGA). I seriously doubt if one out of a thousand riders can "read" the plugs well enough to tell "rich" from "lean" from "spot on". IMHO, the hardest area to diagnose without an EGA is the mid-range, and that is where you do most of your riding! Many worry about changing their main jets and never ride above 6000 rpm enough to really matter. Of course on the dyno you can get a good reading over the whole rpm range. :-D
Larry
Larry
