I just did mine on the weekend with information from others on the Forum.
1. Use a long length of dental floss and wrap it around both hands so you have about 6 inches free (between your hands)
2. Start at the bottom of the reflector and with a continuous steady pull cut the foam tape with the dental floss. The "tink tink sound" you will hear is the rteflector hitting the ground.
3. Cover the rear tire (AND DISC!!!!) with rags and carefully spray the remaining foam with WD40. Let it soak in awhile and spray it again. I say again keep the WD40 off the disc and brake pads.
4. Using your thumbnail work away alternating between scraping, wiping, and spraying until the offening remaining tape is gone.
5. Clean the fender and wax. :-D :-D :-D
" No.....your other left" (Memories to when I was a Motorcycle Instructor)
