RacerPartsWholesaleAnnitori DistributingSportbikeTrackGearTriumphPerformanceUSAMotorcycle.comTrident-Exhausts.comMotorcycle.com Classifieds!AdvanstarMotorcycleShowsSpringfield ArmoryBikeBandit
Annitori.com
Old 07-08-2007   #1 (permalink)
hey guys,
just a quick question. i noticed something yesterday while moving my bike backwards down hill and was wondering if it is normal.
okay. so, i found out that if in neutral, the bike moves very easily with no friction whatsoever. now, i tried putting it in first and held in the clutch all the way in to the grip and noticed that the bike had friction while moving backwards.
is this normal and is there a reason for this? or does that mean that my clutch is not disengaging all the way (hope not). :???: Everyone give it a try! :razz:
kidkazi is offline   Reply With Quote
Old 07-08-2007   #2 (permalink)
Favorite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
raproe's Avatar
The clutch is wet and what you feel is the oil drag between the plates. When the oil is cold it is really noticeable.
Rich
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
raproe is offline   Reply With Quote
Old 07-08-2007   #3 (permalink)
mecscc's Avatar
+1
Monte
Monte
"The Old Ohio Preacher Man"
Old 07-08-2007   #4 (permalink)
Favorite Bike: Definitely my 2007 Black
Hedge's Avatar
Raproe - would that be the same principle when I first start my bike and it is on the senter stand in neutral - the rear wheel slightly spins? If so - that would explain that!
Proud to be an American Infidel!
http://www.thingsididilastnight.com/
Hedge is offline   Reply With Quote
Old 07-08-2007   #5 (permalink)
Hedgefundgeek: Yes.
Marty
Old 07-08-2007   #6 (permalink)
Rich
thanks rich, you genius.
Old 07-09-2007   #7 (permalink)
Hedge geek
With the clutch released (no squeza da handle) and in neutral, the engine is spinning the entire clutch assembly, which in turn is spinning the tranny input shaft, which is spinning all the gears since they are constant mesh. The only thing NOT turning is the tranny output shaft because you are in neutral and so no dogs are engaged to drive that shaft (no gear selected) However, the gears are spinning around that shaft, spinning freely, not mechanically locked to it. There is enough friction transfering to the output shaft to turn it if there is no resistance. So the rear wheel turns slowly.
And yeah, raproe's point is that in neutral turning the rear wheel (manually pushing the bike, power off) is easier than in-gear-but-clutch-in because now you are running the whole scheme backwards. In neutral, you don't have to turn the clutch plates at all. The wheel turns, the chain and tranny output turns, but nothing else turns because no gear is dogged to the shaft. The shaft turns freely. But in gear with the clutch pulled you must also turn all the gears and one set of plate which are very close to or actually in contact with another set of plates that are static because the engine is not turning.
Whew, follow that?
Lets just say its easier in neutral and leave it at that. :???:
merlin is offline   Reply With Quote
Old 07-09-2007   #8 (permalink)
Beware backing a Bonne w/ the stand down!!
CAPT D
Old 07-09-2007   #9 (permalink)
On 2007-07-08 23:00, merlin wrote:
Hedge geek
With the clutch released (no squeza da handle) and in neutral, the engine is spinning the entire clutch assembly, which in turn is spinning the tranny input shaft, which is spinning all the gears since they are constant mesh. The only thing NOT turning is the tranny output shaft because you are in neutral and so no dogs are engaged to drive that shaft (no gear selected) However, the gears are spinning around that shaft, spinning freely, not mechanically locked to it. There is enough friction transferring to the output shaft to turn it if there is no resistance. So the rear wheel turns slowly.
Whew, follow that?
Excellent explanation.
2112 is offline   Reply With Quote
Old 07-09-2007   #10 (permalink)
Hedge's Avatar
Agreed - just a plain out Clear-Cut explanation that can be easily understood. Great Job and thx!
Quick ?: Bonne oil filter # mecscc Twins Technical Talk 13 01-16-2008 03:41 AM
Quick question - need quick answer Poddy Sprint Forum 4 09-04-2007 11:08 PM
Is triumph going backwards kmaultsb Sprint Forum 22 08-01-2007 06:42 PM
Stator on Backwards? rj2006 Classic, Vintage & Veteran 2 08-10-2006 01:29 PM
Quick question, quick response please joeygloor Speed Triple Forum 9 11-24-2004 01:08 AM
