That post is nothing short of brilliant!
I changed my fork springs and fitted gaitors using that link.
If you've got the tools at hand and a block to raise the bike on you'll be fine.
The most important piece of info on that post is: Do one leg at a time.
I had my Buddy round for a bit of camaraderie, but it was relatively easy to do. Took about 1 - 1 1/2hrs to do.
Jon (UK)
